Sale/trade Bagged Mark 8
Old Nov 19, 2008 | 06:03 PM
94mightymax's Avatar
Default Sale/trade Bagged Mark 8
I have a 1994 Lincoln Mark VIII FOR SALE/ TRADE
Suspension: Dominator 2500# bags in rear, Firestone pressure tube 2500# bags in front, 3/8th air line, 4 manifold 3/8th valves, 2 dual needle 200 psi gauges in pillar pod, custom tank setup (3 tanks 16 gallons of air), 2 VIAIR 480C compressors.
Engine: Stock 4.6L V8 Quad cam, custom air intake with heat shroud, custom built 240 amp alternator, stock 4L60W trans, Aluminum driveshaft, stock rear with rebuilt axles.
Interior: Black leather with minimal wear,all power options work, PW, PL, auto headlights, all gauges work, info center works, Power seats, PB, PS, A/C blows ice cold, heat blows hot, all lights work, rear defroster works, 15% tint.
NEW STUFF: Brake pads, brake rotors, brake master cylinder, brake booster, belt, MAFS, plugs, battery.
THE BAD:Needs paint, has a few dings and scratches and has a hand size dent in drivers side quarter panel above rear tire an easy fix, abs light is on because of broke sensor but should have fixed soon, and the check engine light comes on sometimes because the egr is clogged.
I would like to get $3,000/OBO/TRADE (727)-623-8920 call anytime
I have well over $3,600 in the suspension alone with recipts but i know i will never be able to get out what i put in the car.
thanks for looking.
Old Nov 21, 2008 | 08:14 AM
Up To The Top!!!!!!!!!!!
Old Nov 21, 2008 | 08:40 AM
ExPlOReR_oN_DuBs16's Avatar
https://www.tamparacing.com/forums/c...ed-cold-c.html
