93 e.g. b20b turbo for sale
Old Nov 17, 2008 | 04:21 AM
boosted b20's Avatar
Default 93 e.g. b20b turbo for sale
motor built in sept. with new wiseco pistons 8;1 compression, eagle H beam rods, ACL racing bearings in main bearing n rod bearings, Block was defcon for stronger support in the sleeve to push over 400 H.P. n more. its now 280 whp but can push out more. new axles(Both), New clutch but stage 4 to handle 450 h.p. n put it sept. along with new walboro 255 fuel pump, fuel filtor, slave cylinder on transmission, new clutch master cylinder, all new belts including timing belt, new tensioner, new tensioner bolt from honda, new 3 intermediate shaft bolts, new water pump during the build, I put in strut bars front n back, new rear main seals during the build, new O rings on both side of coolant rail, new head gasket, new intake gasket, new manifold gasket, new down pipe, newer t3/t4 turbo put in 2 months ago, basically all new gaskets n seals. Engine has probably close to 4,000 miles on it n runs like a champ. All u need now is ARP head studs, n bigger fuel injector n u can push over 400 H.P. n more. I never finish the build because as u can see I'd spent alot but I'm not trying to sell back for same price I'd put in. I can't finish the build n is really in financial problem. Please let me know n how much u would offer. My number is 239-440-0405, 239-332-7006. The bid starts at 3500. picutres are in my Tampa racing Garage.
