FS: 97 Dodge Neon 2.4 Swap Valrico, FL
Old Nov 16, 2008 | 04:00 PM
jsachnet's Avatar
Default FS: 97 Dodge Neon 2.4 Swap Valrico, FL
Name: Jason Sachinger
Vehicle Location: Hagerstown, MD 21742, Will be in Valrico, FL 33594 after Nov 27th or 28th if not sold in Maryland
Price: $1500 OBO
Contact: jsachnet@gmail.com, PM
VIN: 1B3ES22C1VD150283, Vin Decoder
Mileage: 108,475
Trades: Open to offers for parts for my 2.4L turbo build. Turbos, Cams, Intakes, etc... I cannot accept vehicle trades.
Car is currently in Maryland. It will be back in town (Valrico) around November 27th or 28th. If your interested it can be seen around that time. The Army is sending me to Hawaii for 3 years so I need this gone, I don't really want to let it go but I don't want to store it for 3 years either.
For sale is a 1997 Dodge Neon Coupe. It has a 2.4 from 1999 Stratus with ~65k on it. The 3.94 trans came from a 1997 Neon that had ~70k on it. When I bought the car it needed a new cylinder head due to the #1 cylinder having its spark plug hole stripped and fixed very poorly. The transmission was also replaced as it would not stay in 4th or 5th gear and needed a new throw out bearing.The interior is in pretty good shape. The left side on the drivers seat has started to open up on the seam from the back and front cloth.The front bumper has a crack on the center where the front license plate would go. The passenger side has a dent directly behind the door. You can see it in the pics. That is the only dent but there are other scratches and scuffs.
Notable Modifications:
Re flowed the solder on the Gauge Cluster to fix the speedometer
3.0 Intake Mod with K&N RU-3130
Hedman Header
Balance Shaft Chain removed, balance shaft assembly still on motor
3.94 Transmission
SPEC Clutch, I am not 100% sure which one due to no part number being on the clutch itself but it is at least the stage 1 (SD851) which holds 295 ft. lbs.
Mopar Performance PCM
No Power Steering (Lines looped at Rack) Pump and lines removed
A/C compressor and all lines removed
Solid Bobble Strut
Prothane Motor Mount Inserts all around
New Parts:
Spark Plug Wires
Spark Plugs
Valve Cover Gasket
Spark Plug Tube Gaskets
Camshaft Oil Seals
Camshaft Sensor Seal
Exhaust MLS Gasket
Thermostat
Thermostat Seal
Radiator Cap
Throttle Body to Manifold O Ring
Intake Manifold Upper and Lower Gaskets
Mopar Headbolts
Mopar Headgasket
Water Pump Gasket
Water Pump Inlet Tube O Ring
Inner Timing Cover
Outer Upper Timing Cover
Outer Lower Timing Cover
Mopar Rear Main Seal
Booger Shift Bushings
Mopar Throw Out Bearing
Mopar Axle Seals
My name is csmsach on srtforums which explains the different username in the pics.
Old Nov 16, 2008 | 07:04 PM
ExPlOReR_oN_DuBs16's Avatar
I wish i could swap you neons.... lol i want a 2.4
Old Nov 16, 2008 | 08:18 PM
Thatguysstuff's Avatar
Hey its that guy!!
looks like a good sleeper..!! Is that a Mini Disc radio??? havent seen one of those in years!!
Old Nov 16, 2008 | 09:03 PM
jsachnet's Avatar
lol, yes it is. I wish I had a minidisc to put in it.
