honda parts
Old Nov 16, 2008 | 10:27 AM
DRENICA CUSTOMS AUTO's Avatar
DrenicaCustomsAuto.com
Default honda parts
TAKING OFFERS FOR MOST OF THE PARTS
DRENICA CUSTOMS AUTO.COM
42160 US HWY19N SUIT 26
TARPON SPRINGS
FLORIDA 34689
727-505-5521
WWW.DRENICACUSTOMSAUTO.COM
99/00CivicEkWhite front fenders right and left side
99/00CivicEkCarbon Fiber hood needs re clear coat; hood pin holes
99/00CivicEk right fron head light like new
CivicEk stearing wheel air dark gray
CivicEkspeedo clauster without tec
CivicEkspeedo clauster front face2 pieces
CivicEkfront grill whith H emblem
CivicEkHX model tail lightslike new
CivicEkright side under fender mud guard
CivicEkfront under carriage mud guard
CivicEkrear tail gate/trunk cover with OEM wing & 3rd brake light
CivicEkcomplete AC lines
CivicEkpower stearing lines with resorvar
CivicEkB16 B18 R1 racing competition header1 piece 4/1; 2 1/2 collector
CivicEkD16 RSR competition header 1 piece 4/2/1; 2 1/4 collector
CivicEktrunk plastic piece
2CivicEkD serious shift linkage with shifterhas all the bushings
CivicEkD16 Vtec valve cover painted silver, needs repaint
CivicEkfront HX calipersright & left
CivicEkOEM struds springs
CivicEkD16 upper/lower radiator hoseslike new with OEM clamps
CivicEkHX driver side spindal
CivicEkD series engine mount bracketsdriver side passanger side and T bracket
CivicEkD16 starterlike new
CivicEGFront OEM turning signal right & left side, like new
CivicEGdriver side motor mountused condition
CivicEGAC compressor like new, running condition
CivicEGAC bracket with AC pulley
88/91Honda CRXrear lower control armsright & left side, like new
88/91Honda CRXfront & rear brake roatersall 4 like new condition, freashly machined
88/91Honda CRXfront upper control arms1 month old
Civic Ekfront upper control armsright & Left side, excluding bould joints
88/91Honda CRXJDM carbon fiber hoodlike new, just recleared ( SOLD )
Acura IntegraDC driver side window glass
Acura IntegraDC driver side outside door handle
Acura IntegraDC driver side door hinge
Acura IntegraDC driver side interior door handle
95Accura IntegraB18/B1 valve cover
Acura IntegraDC LS bear head with full stage 5 port & polishno valve train, no valve cover, no
cams 94Acura Integra LS OBD 1 distributer used, 2 in stock
Acura IntegraDC GSR Vtec selenoid complete
Acura IntegraDC GSR complete throtel body with map sensor & TPS sensor
Integra/Civic IACV valves 4 in stock, used condition
88/91Honda CRX AC compressor like new
88/91Honda CRX D16 alternatorworks
Acura IntegraLS half shaft female automatic & 5 speed Honda
CRXB16 OBD 0 complete timing cover plastics
2006CivicSI gauge clauster with pig tail wires
EG/EK radiator fans2 in stock
Acura IntegraGSR complete AC lines
IntegraGSR AC compressor works like new
Honda CRXB16 S1 transmission 3rd gear light grind ( SOLD )
Honda CRXB16 S1 transmission won't go in the 5th gear ( SOLD )
Civic EK windsheald washer tank with motors
Honda CRX front support torsion bars with support
88/91Honda CRXdriver side fender turn signal like new
88/91Honda CRX LS stock pistons with rods & rings & barrings like new, all 4
88/89Honda CRX tail lights 90/91 center piece
88/91Honda CRX SI sun roof frame sun roof p; 2 in stock
Acura Integra DC GSR oil pump used condition, works great
Acura Integra DC GSR lost motion lifters used, but in good condition
Acura Integra Bseries low comp SRP pistons9/1 compression like new mounted on 3 rods, 1
has no rod
90/91Honda CRXfront & rear bumpers red color, front bumper got small crack
CivicEK AC condensor with fanlike new, when pulled out
Acura Integra GSR crank needs to be remachined, # 2 piston spunn a bearing
civic EK power stearing pump like new, also has AEM light weight pulley
Acura Integra GSR AC compressor like new
Acura Integra GSR AC compressor bracket
Acura Integra GSR passenger side torqu mount arm like new
Acura Integra GSR torqu side mount bushings like new, right & left side
P235/70r15MICHelinXC LT4 matching set like new tread 10.32nd, 4 matching set
P205/50R15 good yeareagle GT2 2matching tires10.32nd like new
P225/60R16GoodYearEagle GA one tire10.32nd one tire
P225/60R16MichelinSymmetry 2tires8.32nd 2 tires
P175/70R13RepublicHorizon metrick with 4X100 steal wheel 7.32nd one tire/wheel
P175/70R13BridgestoneInsigniaSE 200 with 4X100 steal wheel4.32nd 2 tire with 4X100 steal
wheel
88/91Honda Crx SI starters used condition, 2 in stock
OBD 0 D16 altenators 3 used in working condition
CRX SI D16 OBD0 AC compressor 1 good working
Acura Integra DA power stearing pump 1 in good working condition, V belt drive
91/93 Acura Integra LS B series power stearing pump 1
91/95 Accura Integra LS power stering pump Serpentine driven 1 good working
92/2000Civic 2 1/2" lowering springs, neuspeed race set of 4Civic
D16 crank pulley like new
Crx right hand front head light good condition
88/91Crx pedale assembly conversion good condition
Crx clutch cable good conditionIntegra
LS AC Bracket with pulley1
EK front upper control arms like new, right & left side
Integra LS rear camber arms good condition right & Left side
Crx SI AC blower fan good condition1
EK rear OEM struds with springs right & left side rear only, good condition
Crx E brake handle 3 good condition
Crx rear glove compartmentsright & left side, black color, good condition
Crx wiper arm motor1, good
90/91Crx steering colum cover plastic
Crx front bumper side brackets fender brace bracket, right & left side, good
88/89Crx fuse box cover 2black 1 dark blue
88/89Crx door panels speaker covers 1 black, 2 dark blue
88/91Crx change compartment 1 black
88/91Crx radio ash tray center piece1 black
88/91Crx right side exterior door handle SI blue 1
88/91Crx window crank handles4
88/91Crx interior mirrow covers2 rights and 2 left all black
88/91Crx trunk & gas release handle cover round 1 dark blue
88/91Crx left foot rest pedal inerior reverse light covers
2B16/GSR timing belt cover complete assembly
1civicradiator fan
civicEG four door corner light left side
Integra B18 timing inside cover 1
Crx OEM mirrows black right & Left hand
Integra LS transmission T bracket 1 like new
Integra DA engine mounts 2 like new
Integra LS engine mount brace
Honda Accord OBD1 F 22 engine distributer2 good
Accord F22 engine throutle bodies with map sensor and tps sensor
civic OBD1 with map sensor, no tps sensor 1 good
Integra OBD1 GSR throuder body no map senosor, has tps sensor1
Integra OBD0 throudle body without tps sensor2
civic OBD1 distributor for D16 OBD1
Vtec selenoid assembley with broker pressure switch
EK OEM shifter
prelude OBD1 injector resister box
88/91Acura Integra DA after market tail lights right & left
Crx fuse box assembly
88/89 Crx RH LH door strips
Integra LS brand new crank shaft
Integra DAignicion switch assembly
Civic Left outer tirod brand new
88/89Crx door piller caps
90/91Crx center tail light piece1
88/89Crx center tail light piece1
88/91Crx AC condensor
88/89CRX fender turn signal assembly RH & LF
88/89CRX right side bumper turn signal OEM1
88/91Integra LS right side bumper turn signal 1
88/91Integra DA fender turn signals right & left hand
CivicD16z6 OBD1 distributer like new 1
Honda prelude OBD2 distributer like new 1
88/91Integra LS valve cover red 1
88/93 Integra 5 speed clauster reading 157250
CivicEG 4door after market turn signals RH & LH
Integra GSR OBD2 timing belt
Integra LS water pump like new
88/91Crx radiator bracket3
CivicEk steering wheel air bag
90/91Crx rear view mirrow good
OBD0 IACV valve 1
Crx horns4
88/91 interrior left side tail light cover
Integra DA upper power stearing bracket2
88/91Crx Dserios alternator bottom bracket 1
88/91interior door handle 1
88/91Crx interior air vents
88/91Crx clock and center vent good
EKrear strud mounts2
88/91Crx fuel flex line by the fuel filter
88/91Crx interior fuse box
88/91 Crx engine bay fuse box 2
Integra DC2 complete AC lines
Integra DC2 AC condensor
88/91Crx SI radiator
I SELL USED MOTORS AND TRANS AND AUTO PARTS PM ME WITH YOUR NEEDS
TR "Old Skool EF" Member #056
Old Nov 16, 2008 | 10:39 AM
sirt8669's Avatar
私は昼食のためのあなたのお母さんを持っ ていた
That is not easy to read, haha.
"I love Asian chocha" crew member #001
"Anime Freak" Crew Member #001
Old Nov 16, 2008 | 10:42 AM
customkid72's Avatar
umm i have a seriuos head ache
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Old Nov 16, 2008 | 10:43 AM
Willis's Avatar
change the font color you cant even read it...
Old Nov 16, 2008 | 10:44 AM
92 CiviC H/B's Avatar
-Proud Croatian-
woww.....i agree ^^
you should make a list..not an essay lol.
.TR's OldSkool DA Crew Member #14.
Old Nov 16, 2008 | 10:57 AM
Paulino's Avatar
Not harsh, just truthful
Originally Posted by 92 CiviC H/B
woww.....i agree ^^
Holy hell ^ X a billion...bump for a MASSIVE storage..
Old Nov 16, 2008 | 11:30 AM
shit i still got allot more to go
Old Nov 16, 2008 | 11:33 AM
jfr32988's Avatar
EL REY COLOMBIANO
pmd u adem
Jay's Avatar
Jay
Janky
oh my im not reading all that you got any obd2 once cam dizzys
Aim: o JankyJ o
http://jankycrew.com
Paulino's Avatar
Do you just collect Honda/Acura parts for fun dude?!
