Wtt-my 89 Si Crx Turbo Project For-00+ Bike Any Brand___
Ok Here It Is What Im Offering To Trade -
ENGINE SPECS
OK HERE IT IS THIS IS MY SWAP I WAS GOING TO BOOST SAD TO SAY
-I FINSIHED MY IROC Z AND SHE NEEDS MY TIME AND LOVE AND IM MOVING OUT OF HERE OR GONNA TRY--
SO HERE ARE SPECS
OK HERE SHES IS ITS MY REX
OK 89 SI REX
HERE ARE SPECS
INTERIOR
SI SEATS
SI DASH
SPARCO LOOK ALIKE STEERING WHEEL
SI PANELS
REAR SECTION INSIDE
ALL REAR WINDOWS BLACKED OUT -CAN BE REMOVED IF WANT VERY EASYLY.
REAR END OF BODY IS PANTED BLACK
FULL SI SUSPENSION
17INCH TSW RIMS FUZION TIRES
AUTO METER MONSTER TACH NEEDS INSTALLATION
SI SUNROOF FULLY OPERATIONAL
BODY-CLEAN
PAINT IS PRIMER BLACK
SI FRONT BUMPER
SI REAR BUMPER
SI FRONT END
SI HEAD LIGHTS
MINOR DENT ON FENDERS EASY REPAIR
WINDSHIELD NEEDS REPLACING-INSURANCE WILL DO IT FOR FREE
BASICALLY THATS ITS
FULL WIRING,ENGINE N INTERIOR ALL FUNCTIONAL ,
IT HAS DPI HARNESS READY TO BE CONVERTED
I WILL GET PICKS UP TONIGHT.
BUILT Z6 HEAD-
OEM CAM
OEM SPRINGS
OEM RETAINERS
NEW GUIDE SEALS
NEW VALVES-HONDA
SHAVED HEAD
MILLED
STAGE 1 PORT N POLISH
Z6 VTEC SELANOID
BLACK VALVE COVER SAYS HONDA VTEC
NEW PLUGS
NO DIZZY- DONT HAVE ONE SO DONT ASK
D15B8 BOTTOM END
OEM PISTONS
OEM RODS
ACL MAIN BEARINGS
ACL ROD BEARINGS
POLISHED CRANK
BOTTOM END PAINTED BLACK
NEW WATER PUMP
NEW HONDA OIL PUMP
NO TIMING BELT NEED TO BE PUT IN TIME ITS EASY- SWAPPED HEADS NEED Z6 TIMING BELT BUT HAD NO CASH.
TRANSSMISON
EXEDY-STAGE 1 DISK
EXEDY STAGE 1 PREASURE PLATE
EXEDY STAGE 1 THROW OUT BEARING
ORIGINAL SI 91 TRANSMISSION
MINT GEARS
MINT RINGS
MINT PINS
EVERY GEAR IS LIKE ITS BUTTER
ENGINE SPECS
SO HERE ARE SPECS
OK 89 SI REX
HERE ARE SPECS
INTERIOR
SI SEATS
SI DASH
SI PANELS
REAR SECTION INSIDE
FULL SI SUSPENSION
BODY-CLEAN
SI FRONT BUMPER
SI REAR BUMPER
SI FRONT END
SI HEAD LIGHTS
BASICALLY THATS ITS
BUILT Z6 HEAD-
OEM CAM
OEM SPRINGS
OEM RETAINERS
NEW GUIDE SEALS
NEW VALVES-HONDA
SHAVED HEAD
MILLED
Z6 VTEC SELANOID
NEW PLUGS
D15B8 BOTTOM END
OEM PISTONS
OEM RODS
ACL MAIN BEARINGS
ACL ROD BEARINGS
POLISHED CRANK
NEW WATER PUMP
NEW HONDA OIL PUMP
TRANSSMISON
EXEDY-STAGE 1 DISK
MINT GEARS
MINT RINGS
MINT PINS
