F/s Honda Parts Need Gonee
F/s Alot Honda Parts Wanna Get Rid Of!!
P06 Ecu-$25
Obd2 To Obd1 Converter Harness-$100
Si P2t Ecu-SOLDDD
Si Wire Harness-SOLDD
Si Fuse Box-SOLDDD
EX SUNROOF WINDOW-$10
Si Power Steerin Pully-$25
Integra Driverside Bracket-$25
Sohc Throttle Cable-$30
Sohc Aem Blck Adj Cam Gear-$65
Eg Oem Head Lights-$25
EG MOUNT FOR B-SER SWAP THE SIDES MOUNTS ARE BRAND NEW THE BAK ONE IS USED-$85
Sohc Shift Linkage-$30
Sohc Skinny A/c Line-$15
Used Radaitor-$15
B16 Stock Headers-$10
T Bracket With The Hole In The Middle-$30
17in Blck And Chrome Rims-$45
Also Hav A D15 Motor With B;own Block-$85
Or Partin Out If Anyone Needs Anything & Itz Non Vtec
I Thik I Hav Other Things But If Anything Holla At Me If U Want Pixz Of Anything
ILL TRADE FOR EX CLUSTER , CAMBER KITS, OR EG FOG LIGHTS
P06 Ecu-$25
Si P2t Ecu-SOLDDD
Si Fuse Box-SOLDDD
Used Radaitor-$15
