The Ultimate B Series Part Out
I have alot of b series parts for sale.
2001 gsr tranny $600
si factory head lights $60
skunk2 shift knob $35
front and rear strut bar front is type r rear is ebay $50
b series shift linkage and stabilizer bar $75
complete b16 head : valve cover, itr valves springs retainer cams and cam gears vtec solenoid 7000 miles on the rebuild of the head $500
fidanza flywheel $100
act clutch $100
spec clutch $75
nos nitrous dry kit $300
nos wet kit $600
brand new nos bottle $125
h22 turbo manifold $75
gsr saw blades no tires $250
glow shift boost gauge $25
oil feed and return kit $50
knock off greddy blow off valve $50
greddy bov flange $20
b series rear motor with es inserts $30
b series solid upper drivers side mount $50
b series drivers side lower compressor bracket and mount $75
b series power steering pump $75
vtec solenoid $40
b16 engine harness $75
ej6 4 door red and clear tail lights $75
entire ac system $175
si fuse box cover $10
battery tray and tie down $25
radiator with fan and hoses $100
b16 throttle body $60
b16 air control valve $50
b16 fuel rail with stock injectors and reg $75
b16 thermal intake manifold gasket $20
k20a2 ecu $125
virgin p28 $100
odd2-obd1 harness $50
b series shift fork and spring $15
complete jdm b16a $1400
brand new hondata s300 $500
greddy evo exhaust $250
test pipe $40
ls integra seats $150
38mm wastegate $50
itr header $200
si carbon fiber hood $250
b series axels with half shaft $100
si cluster 78,kkk miles $100
aem v2 cold air intake $75
b series starter $75
b series alternator $75
rear t bracket $50
I'll post more stuff later and if there is anything that you are looking for let me know.
red = sold
yellow = pending sale
act clutch $100
spec clutch $75
nos wet kit $600
vtec solenoid $40
k20a2 ecu $125
virgin p28 $100
test pipe $40
38mm wastegate $50
itr header $200
rear t bracket $50
red = sold
pm'd
BEATS FOR SALE...check out
www.myspace.com/mercademus
{RI AUTOMOTIVE/RACING INTEGRATION>813-935-6720<}
