Lots Of New And Used Dohc Vtec Parts. Take A Look!!
Old Mar 5, 2008 | 06:59 PM
DOHC16CRX's Avatar
CARPET GUY
Exclamation Lots Of New And Used Dohc Vtec Parts. Take A Look!!
WELL I DONT EVEN KNOW WHERE TO START.i have tons of parts still and i need to get rid of some of this.my prices are pretty much firm so please no low ballers.i have lots of little hard to find head and block parts/bolts/sensors you name it so if not listed just send me a pm..here we go.
JDM B16B CTR 81mm pistons.these are straight from japan.they are brand new in the box.these pistons have tefflon coated skirts to reduce friction.these are excellent for any B18A,B18B,B18C,B16A LS/VTEC. These come complete with new wrist pins and rings.all new in box. $170
98 gsr block w/ a bad sleeve in the 3rd cylinder.needs 1 sleeve.all others are perfect..standard 81mm.the wrist pin backed out and put a huge groove in it.this is blobk only.Perfect for sending in for sleeveing.$60
97 b18b block w/ main caps and bolts.comes with a few extra parts.needs a bore from sitting and surface rust. $75
98 gsr crank. Its in ok condition.has a few light grooves.$50
gsr main caps w/ all the bolts.this includes the girdle w/ the 2 end caps.perfect for ls/vtec.in mint condition.$100
JDM GSR oil cooler COMPLETE w/ everything needed to install onto any dohc vtec.excellent for lsvtec as well.this comes with the cooler,the stud that connects the cooler and filter,all hoses,the main coolent tube and therm. houseing w/ all bolts.you will need nothing to install.its all here.$100
USDM OBD2A P72 ecu $70 SOLD
NEW OBD2 GSR distributor.never installed. $120 SOLD
New in box BAY CITY CLUTCH 2500lb pressure plate.never installed.this is there HD pressure plate.works as well as the ACT. fits any dohc tranny/flywheel.$100
Act used pressure plate.in nice condition.very low miles.this is the HD plate.fits any dohc vtec.$100
New in box OEM ACURA gsr p72 oil pump.only opened for pics.$100
New in pack OEM ACURA p72 gsr water pump.$60
Oem acura new in pack DOHC VTEC valve seals.make offer
OEM new in pack timeing belt tensioner.$40
OEM P72 timeing belt.new in pack $40
oem p72 main seals.new in pack. make offer
93 LS A1 CABLE TRANNY.This tranny is in mint condition. no grinds at all.will fit any dohc vtec. $200
96 gsr S80 TRANNY W/ KAAZE LSD. this was built for me by vance in lakeland last year.i still never even used it.This is the 50/50 style lsd not the cheap 60/40. lsd alone is around $960.i have pics of all gear stacks when being built.you can see how clean all the gears are.NO GRINDS AT ALL IN ANY RPM.THIS TRANNY IS MINT.it also has new axle seals.this is for the serious racer.You get what you pay for.i have around 1900-2000 into it. will NOT sell for a penny less then $1200
gsr alternator mounts$20
jdm GSR oem obd1 oil pump. works perfect.very low miles.i have the timeing belt covers for this pump to. all for $50
2 gsr main caps.$20 ea.
stock p72 gsr rods.in good shape.no spun bearings.3 have pistons. $30
jdm B16A obdo axle half shaft. in mint condition.$50
itr throttle cable.mint $ 25
stock gsr valve cover.from a 98.it needs cleaned up.uncut and no damage beside the black flakeing paint. $50
Oil squirters w/ bolts.all 4 $40
GSR mint crank 3 BELT pulley w/ bolt and key $50
obd2 crank angle sensor w/ mount and bolts $40
obd1,obd2 and obdo crank gear for timeing belt.i have all 3 w/ the washer to hold the belt.20 ea.
crx MINt outer tie rods(both sides) w/ energy suspension bushing covers.mint $25
OBD0 DOHC clutch disks.both are perfect.look like new $20ea
OBD0 B SERIES starter's.1 is brand new.used 4 times.$100 for it. have the same exact starter used for $50
obdo alternators $40 ea.
sohc cable standard tranns pass side axle.mint. $30
pr3 cam gears $20
OBD1 GSR oil pump.62k miles.in excellent working condition.$50
p72 GSR water pump.used.in perfect condition 62k miles.$25
SKUNK2 long wheel studs w/ the skunk lug nuts 8 of them.new $50
15" 205/50/15 G-FORCE DRAG RADIALS 40 miles on them.no camber wear.in 9 out of 10 condition.i payed 149 ea.sell for 160 for the set of 2.
i will post more tomarrow..its getting late.pm me if interested.thanks..NATE
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Mar 5, 2008 | 09:58 PM
YBlegal's Avatar
Broke not Built
i may get a couple things from you....ill let you know.... free bump
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Mar 6, 2008 | 12:17 AM
rangcrx's Avatar
engine building &best
Looking around
i love AUTOZONE
Old Mar 6, 2008 | 12:04 PM
DRENICA CUSTOMS AUTO's Avatar
DrenicaCustomsAuto.com
i need to know you'r location i need that 0bd2 dizzy
I SELL USED MOTORS AND TRANS AND AUTO PARTS PM ME WITH YOUR NEEDS
TR "Old Skool EF" Member #056
Old Mar 6, 2008 | 12:20 PM
EclipseTurbo94's Avatar
omd u on valve cover
i also need
1,valve cover
2.vtec salenoid
3,knock sensor
call me got cash today
727-244-8277
Old Mar 6, 2008 | 04:41 PM
J-PEZ's Avatar
Professional Hussla
does the gsr block come with main caps and girdle??? Also is ilajit and can you provide a reciept if I buy it, lmk thanks
Cheap Honda Parts! TypeR, civic, AEM, eagle, and more. W/pics! Check it out
___________________________
Tranceologist Powder Coating
Old Mar 6, 2008 | 07:26 PM
DOHC16CRX's Avatar
CARPET GUY
yes the block is legit.i am 30 not some kiDstealing cars and parting.i will give you reciepts all day.i just 3 days ago pulled it from a 98 gsr.if you want the main caps and girdle the price is 100 more. i sell them on ebay for that all day plus they are great for ls/vtec.I have every OEM ARURA gasket as well as new OEM oil pump and water pump in the plastic.if some1 was wanting to build a nice ls/vtec OR ANY DOHC VTEC I have just about EVERY seal in the wrap and i ONLY buy oem gaskets AND I KNOW you guys know how expensive anything from honda is.i have a good 800 plus in oem parts.yes they cost more then cheap ass discount felpro junk but u get what you payfor and we all know there is nothing like oem parts as in quality.I am located in cleawater right by clearwater high on 60(gulf to bay).
Old Mar 6, 2008 | 10:36 PM
rangcrx's Avatar
ttt this is a 100% great seller ttt
i love AUTOZONE
Old Mar 7, 2008 | 05:31 AM
hello i want ur valve cover so if u wanna sell it then send me ur number ill buy today
Old Mar 7, 2008 | 11:52 AM
DCLove05's Avatar
pm'd but your box was full. call me 727-698-4587 asap, I LIVE IN CLW I need parts!!!
