For Sale 95 Civic With Turbo Gsr
Old Dec 24, 2007 | 10:34 AM
fred4455's Avatar
Exclamation For Sale 95 Civic With Turbo Gsr
car interior
1- acura integra type-r seats usdm
2- power windows and power locks
3- custom aluminum gauge bazel in dash around speed,fuel,temp. ect.
4- short shifter with greddy shift knob
5- greedy profec b spec 2 boost controler
6- greddy turbo timer
7- aem wide band 02 gauge
8- power sunroof
9- water temp. gauge
10- egt gauge
11- volt meter gauge
12- boost gauge
13- 2 gauge a-pillar gauge holder
14- fuel pressure gauge (not hooked up)
15- oil temp gauge (not hooked up)
16- auto page car alarm with remote pager
17- aem ems 1040 for gsr
car extrior
1- carbon fiber hood and fenders (need to be reclear coated)
2- volk racing aluminum 17" wheels with nitto low pro tires-bronze
3- power adjustable mirrors
4- stock tail lights
5- new rear bumper cover (not installed)
6- new front bumper cover cut out for front mount (not installed)
7- projector style head lights (not h.i.d.)
8- amber turn signals
9- ingalls fully adjustable camber kit
10- front upper strut bar by tunabe sustec
11- rear upper strut bar by tunabe sustec
12- rear lower strut bar by tunabe sustec(not installed)
13- ebc red brake pads for front rotors
14- power slot cross drilled and slotted front rotors
15- tien adjustable coil overs with dampining control
16- prothane busing kit(drivers front not installed)
17- reloated battery in sealed moroso battery box
18- 15 gal. fual cell with sponge inside of cell
19- 10 pound nitrous bottle with bottle holders
20- extra 10 pound nitrous bottle
car engine
1- integra gsr 1.8 liter engine
2- erl cylinder sleeves
3- bme aluminum 84mm pistons
4- bme aluminum rods
5- new acl main bearings
6- new acl rod bearings
7- stock gsr crankshaft
8- pro drive oversized oil pump
9- moroso high capacity oil pan with oil pickup
10- ati fluid damper
11- new rear main seal
12- new front main seal
13- gsr 1.8 liter head
14- cometic 84 mm headgasket
15- hondata air intake gasket
16- str cam seal
17- stock gsr distributor
18- str adjustable cam gears
19- stock gsr cams
20- msd ditributor with coil driver(needs to be fixed by msd)
21- ferrea .5mm oversized vavles titanium intake and exhaust
22- gsr lost motion assembalies
23- ferrea bronze vavle guides
24- ferrea titanium dual springs
25- ferrea titanium spring retainers
26- full race port
27- str intake manifold with direct port fitings already installed
28- mr. gasket gsport 70mm throttle body
29- aem fuel rail
30- msd 1000cc fuel injectors
31- arp head studs
32- fuel pressure gauge mounted on fuel rail
33- aeromotive fuel pressure riser 1:1 rise
34- aeromtive 1000 h.p. fuel pump
35- aeromotive fuel filter
36- fuel line feed -10 an
37- fuel line return -8 an
38- dei fuel cooler hooked up with nitrous
39- dei intercooler spray bar hooked up after fuel cooler
40- new water pump
41- love fab ramhorn stainless exhaust header with v-band for wastegate
42- full 3" stainless down pipe with 3" flex pipe v-band hook up
43- full 3" aluminum thermal exhaust
44- down pipe wraped in dei header wrap
45- tial 44mm wastegate with stainless dump tube with v-band hook up
46- 3" aluminum itercooler piping
47- precision 750h.p. front mount intercooler
48- tial 50mm blow off vavle with v-band hook up
49- fluidyne aluminum radiator
50- blue electric flex-a-lite radiator fan
51- gm 3 bar map sensor
52- gm air intake temp. sensor
53- precision t4/t67 turbo charger with v-band for exhast hook up
54- prodrive drag spool(not installed)
55- integra twin disc clutch
56- prothane motor mount inserts
57- full engine balance and blueprint
58- greddy oil catch can
59- 1/0 gauge wire with fuse for fuse block
whats wrong with the car
1- needs some body work(minor dent and dings)
2- needs new trim moldings around windows and doors
3- needs new paint
4- needs roll cage
5- needs drag slicks
6- needs race axles
7- needs race transmission
8- needs tune
9- needs bigger injectors
This car should make around 700+ horsepower and 550+ ft pounds of torque. The intent of this car was to be a track car. If you are looking for a daily driver then this car is not for you! The car does not have a/c or power sterring. I have invested alot of time and money in this car but i dont have the time or money to finish it. If you are interested in the car please give me a call so you can come and see it (813)927-3594 Thanks Jimmy.
Old Jan 3, 2008 | 05:12 PM
mailman2008's Avatar
how much$???
Old Jan 8, 2008 | 01:57 PM
fred4455's Avatar
give me a call
Old Jan 8, 2008 | 02:05 PM
00siboy's Avatar
Bone Stock
pics??
-Darren
03 Cobra Vert: Whipple, Lt's, H-pipe, SRA, 325 MT Dr's, more bolt-on's - Weekend Beater
88 Mustang Coupe: Gutted - Project
