1994 Pontiac Firebird Formula LT1- $1700/Trade
Old Dec 22, 2007 | 07:59 AM
Jus10dun's Avatar
Default 1994 Pontiac Firebird Formula LT1- $1700/Trade
This is a 1994 Pontiac Firebird Formula, that has a fully assembled block with all parts with the exception of cracked aluminum heads. It has a LT1 350, Automatic Trasmission, T-tops (don't leak), Teal exterior, white cloth interior, 16 inch 2001 Z28 Camaro rims with Falken P245/50ZR16 Fronts- 70% Rear- 50% thread, new battery.
I bought the car 2 months ago from an elderly lady. i bought it with the intension of fixing it and driving it. When i bought it had a broken transmission mount, that turned out to be a missing bolt that i havn't fixed yet. And an exhaust leak from a broken off stud that caused a blown gasket (on both manifolds). i noticed it was burning coolant. Thinking it was a blown head gasket i pulled the heads, only to find that the gaskets were fine. I took the heads to a machine shop and after $400 of machine work relized one of the heads were cracked.
-List of Pro and Cons-
Exterior
-Pros-
Trans Am Honey Cone taillights
2001 16 inch Z28 Camaro Rims Falken P245/50ZR16 Fronts- 70% Rear- 50% thread (also will throw in the stock firebird wheels)
-Cons-
Front clip paint is faded
Roof by T-tops is faded and clear coat chipping
Small dents on bottom under door
Light door sag
Broken headlight motors, both (common firebird problem)
Interior
-Pros-
Good condition
Cloth buckets
No rips
Cd player, working condition
Power windows
-Cons-
Needs headliner and carpet
Dashboard crack down middle not bad but i have a black dash cover
Driver seat won't recline forward
Only two speakers, and one cuts out
No center console arm rest lid but console is nice
A/C blows but not cold. Needs o-rings (got system checked).
All glass good, no cracks.
Engine
-Pros-
KN air intake system
Bone stock LT1
Ran clean besides coolant
No noises and doesn't burn oil
Stock manifolds and stock exhaust
-Cons-
Disassembled top end
Cracked heads, port and polish with full machine work.
Suspension/Brakes/Underneath
-Pros-
Very clean undercarraige
Stock suspension, road clean and tight
No clunks or noises
Cars sits even
Four wheel disc brakes
3.32 posi in a 10 bolt w/good straight axles
Pan hard bar (stabalizing arm going from tranmission mount to rear end for added traction)
Florida car no rust good floor pans
-Cons-
Brake rotors are rusted.
Stock suspension and brakes
This is a good clean car with a clean FL title in my name. Great starter project. All sales are final, will accept trades, Cash only. No payments. must pick up bring trailer car does not run. Comes with four firebird rims and tires, extra radiator (one in car is in perfect working order just have extra), new exhaust gaskets, and all parts from the car when running.
Contact me @
My name is Justin
Phone: 352-650-8425
Email: Jus10dun@yahoo.com
I live in Weeki Wachee/Springhill, Fl 34613
