Moroso oil pan, GSR dizzy and Steel braided lines
Old Nov 4, 2007 | 12:22 PM
Willis's Avatar
Default Moroso oil pan, GSR dizzy and Steel braided lines
Moroso 5.5 quart oil pan with kickout for LS or GSR used for 200 miles mint!
* Kicked-out sump that increases oil capacity to 5.5 quarts
* Two trap door baffles keeps oil contained in pickup area
* Works with OEM exhaust manifold and most aftermarket exhaust/header combinations
* Turbo/Supercharger oil drainback
* Features a magnetic drainplug and temperature sensor bung provision
* Use with stock Honda oil pan gasket
* Clear zinc plating for durability and corrosion resistance $200
Moroso LS oil pump pickup, needed for the larger oil pan. $40
Dizzy king GSR dizzy used for 50 miles works great OBD2 $160
Misc. -10AN lines in different lengths with straight ends and well as 90 degree bends.
Also have working cruise control box. make offer
Old Nov 4, 2007 | 04:00 PM
Willis's Avatar
pics up!!!
Old Nov 4, 2007 | 04:55 PM
shaggy97's Avatar
S1 member
will you trade the oil pan and pick-up for full gsr rear disc brake conversion?
Old Nov 4, 2007 | 06:02 PM
Willis's Avatar
NO trades
Old Nov 4, 2007 | 07:29 PM
EclipseTurbo94's Avatar
pm the lowest youll take on the oil pan
Old Nov 5, 2007 | 01:18 PM
Willis's Avatar
Old Nov 5, 2007 | 03:40 PM
clean teg's Avatar
Old Nov 5, 2007 | 03:42 PM
kumar.'s Avatar
wrd.
do you know if an obd2 dizzy will work on a obd1 engine?
"Success is 99% failure" -Soichiro Honda
Old Nov 5, 2007 | 03:45 PM
Willis's Avatar
yes it will, but you have to splice the wires or buy a conversion harness.
Old Nov 6, 2007 | 02:46 PM
BABILLARACING's Avatar
pm sent on oil pan and oil pick up
