Complete NOS wet kit for sale with msd. 100% ready to install
Like the title says I have for sale a 100% complete NOS wet nitrous kit for sale. I'm asking $600 obo for everything. Everything this kit includes is as follows :
electric blue NOS 10 pound nitrous bottle
metal bottle brackets
15 foot 4AN steel braided line
all AN fittings
NOS fuel solenoid
NOS nitrous solenoid
steel braided line for fuel delivery
fuel tee
2 steel braided lines that go from the 2 solenoids to the nozzle
NOS wet fogger nozzle
75 hp jets ( fuel 24 nitrous 36 )
dual solenoid mounting bracket
2 relays with wiring harness
NOS wide open throttle activation micro switch
MSD rmp activated window switch
ignited main rocker switch
step by step picture installation diagram
this kit is 100% complete all you would need to do is fill the bottle and install it in your car.
with everything I have for this kit the way it is intended to be used is, the valve on the nitrous bottle has to be open the master switch has to be one whatever you set the msd rmp activated window to is when the nitrous will kick on and shut off. so say your car redlines at 8000 rpm what you can to do it have the nitrous activate at 3000 rpm and shut off at 7000. so bottle open switch on as soon as you go wide open throttle and you reach 3000 rpm (or whatever you set it to) the nitrous will kick on and then shut off at 7000 rpm (or whatever you set it at) and since it shuts off 1000 rpm before redline you can still safely full throttle shift the car. this is the safest way to run wet nitrous and still be able to full throttle shift your car. On average a wet 75 hp shot will take off about 1.5 - 2.0 seconds off of your 1/4 mile time. if you have any other questions feel free to ask.
the only things not pictured are the jets and fuel tee
all AN fittings
NOS fuel solenoid
fuel tee
