Built Ls/vtec
Old Oct 31, 2007 | 12:41 PM
godzhand's Avatar
Default Built Ls/vtec
$4000OBO
LS/VTEC
JDM B16 Head
Skunk2 Valves
Skunk2 Retainers
Skunk2 Valve springs
Hondata Intake Manifold Gasket
H22 Throttle Body
00' SI B16 Intake manifold
H22 LMAS
00' ITR Cams
b16 Cam Gears
3 angle valve job
B18 Block
OBD1
GSR Water pump
Wiseco 81.5mm pistons 8:1 Comp
Golden Eagle Rods
ARP Rod Bolts
ARP Head Studs
Cometic Head Gasket
ACL Race Bearings Main and Rod
Micropolished Crank
Blue printed and balanced by engine Labs
Tranny
LS Trans NO GRINDS
Custom stage 3 clutch, pressure plate & 8LB Fidanza Flywheel 2k miles
Stage 1. Gator Axles just 500miles
OBD1 Custom vtec Harness made by engine Labs
5-10k miles since Rebuild
maintenance
all seals are new
New timing belt
New Timing belt Tensioner
Tranny fluid changed
Oil changed every 2k-3k miles
Head gasket changed 3 times since build idk I get bored
Compression tested 150 150 150 150
Leakdown test 5% 5% 6% 5% which is great, thats pretty much a broken in motor I have leakdown tested brand new engines and they dont even come out that good put a smile on my face when I did this test anywhere from 0%-10% is damn good......
Old Oct 31, 2007 | 12:47 PM
effDOHC's Avatar
About That...
not willing to part right?
Old Oct 31, 2007 | 12:51 PM
godzhand's Avatar
never took me too long to build it im not about too break it apart lol
Old Nov 1, 2007 | 05:14 AM
godzhand's Avatar
Ok people my new motor is almost here so I'm doing a crazy price drop on this built swap 3K firm takes it today
Old Nov 1, 2007 | 06:42 AM
godzhand's Avatar
3k I will throw in a brand new quaife lsd 4300 I will include the lsd and my turbo kit
Old Nov 1, 2007 | 08:21 AM
sleepinsol's Avatar
starting over
.....how big is the h22 tb? would u do a straight trade for a gsr one. im lookin for a bigger one. ill throw cash on top if need b. just a thought.
Old Nov 1, 2007 | 10:51 AM
godzhand's Avatar
Sorry but the motor is being sold complete I will not break any of it down BUMP 3K for a sick boost motor and no one is interested
Old Nov 1, 2007 | 07:13 PM
godzhand's Avatar
Ttt
Old Nov 2, 2007 | 11:14 AM
godzhand's Avatar
$2500 firm takes it
Old Nov 2, 2007 | 11:28 AM
wearyfurball's Avatar
Nice build man, but you do understand this is TR right? No one on here has that kind of money..... good luck
