Fully Built Block, CTR head, AEM EMS, 1000cc injectors, ACT clutch, etc
Old Oct 23, 2007 | 12:53 PM
JDM.Squeek's Avatar
Default Fully Built Block, CTR head, AEM EMS, 1000cc injectors, ACT clutch, etc
Fully Built LS Block
B18B1 Block
AEBS T-Sleeves 86mm
JE Pistons 9.1:1
Total Seal Piston Rings
Eagle H-Beam Rods
VTEC Oil Pick up
VTEC Oil Baffle
VTEC Oil Pump (Type -R)
VTEC Water pump
VTEC Dowel Pins
Brand New Honda Timing Belt
Golden Eagle Head Studs
Alternator
Everything installed professionally, all clearances checked, Engine balanced, comes with all normal parts like the oil pan, tensioner, pretty much ready to go.
PRICE $2,000.....$1,800.....$1,600!!!
PICS
PR3-3 EK9 Civic Type-R Head
Head comes COMPLETE:
Mild Intake Port
Port Matched CTR intake manifold
Throttle body
CTR Camshafts, cam gears
everything else is stock (CTR)
All sensors on head and intake manifold including map, and TPS on throttle body
Intake Manifold Spacer (up to 30 degrees cooler, In. Temp)
High Volume Fuel Rail w/ Guage
NO INJECTORS Look down on the list!!
PRICE $900 O.B.O SOLD
Pics
AEM EMS OBDI Honda/Acura (1040)
Price: $800 SOLD
GSR Hydraulic Tranny
No grinds and goes into every gear smoothly
Includes NEW starter
Price $400 o.b.o. SOLD
Turbo Manifold and Waste Gate (as seen in pics)
-XS Power Race Top mount Turbo Manifold T4 Flange
-XS Power 60mm Wastegate (V-Band also, refer to pics)
LOWERED PRICE: $200 o.b.o. SOLD
Pics
more pics up later
Garrett Turbocharger (from pics above)
.70 A/R front, .68 A/R rear. Back housing was changed to a master power V-band. The bolt treads for the downpipe on the original garrett back housing stripped. Original Garrett internals!
PRICE: $500 SOLD
Siemens 1000cc Injectors (Flow tested!)
Lowered Price $200
Pics
OBDI VTEC Distributor w/MSD SS Coil w/Wire
Price $120
B-series axles (BOTH, Great condition)
Price $80 for both
Old Oct 23, 2007 | 02:09 PM
godzhand's Avatar
The top mount never broke or had to be rewelded??????
Old Oct 27, 2007 | 06:57 PM
SloCxHatch's Avatar
No "V-TECH" here!!!
CALL ME ASAP tonight if possible 813 326 9980 -matt
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
Old Oct 28, 2007 | 10:07 PM
JDM.Squeek's Avatar
^^Sorry bro I sold the clutch^^. THE BLOCK AND THE HEAD ARE A STILL!!!
Old Nov 7, 2007 | 01:13 PM
JDM.Squeek's Avatar
Bump...
Old Nov 10, 2007 | 11:58 PM
JDM.Squeek's Avatar
Lowered The Price On The Block!!!
Old Nov 11, 2007 | 09:31 AM
JDMjunkie's Avatar
bad ass parts you got there
TampaRacing's DEAD!!
Old Nov 11, 2007 | 10:21 AM
-OneFastREX-'s Avatar
Growe Motorsports
any trades on the head with turbo and turbo mani?? I have two ls heads one is complete with stage 3 cams the other with stage 2 cams with bdl industries FULLY adjustible cam gears no dizy or intake manifold will throw some cash on top if u prefer... pm me asap plz
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Nov 11, 2007 | 10:34 AM
sleepinsol's Avatar
starting over
all i need is the throttle body. would u part it? i have another to give if u like. i just need the bigger one lol.
Old Nov 11, 2007 | 01:11 PM
civicmotorhead's Avatar
pm'd
