Free Z32 300ZX parts
91 NA Transmission - Needs an input shaft bearing, a little grind when going into 2nd, as far as I know ~175k miles
93 NA Transmission - Bought this for $100 in unknown
condition, ends up it also needs a bearing and I think the syncros are on their way out because it's a little noisy. It shifts real smooth though and has no grinding going into any gears ~150k miles
91 NA 2+0 two piece driveshaft. CSB still in good condition, no vibrations etc
91 NA 2+0 stock exhaust mid pipes maybe (not sure the name of this part, goes from headers to cats)
91 NA rear differential, still in good condition, just a tiny bit of noise from it ~180k miles
91 NA both half shafts, still in okay condition, I picked up a new diff that came with half shafts so I just switched everything when I dropped the subframe ~180k miles
Used OEM clutch & pressure plate, not sure of miles, I put about 1.5k miles on it and it feels good, not slipping or anything.
Misc parts from an auto to manual swap that never took place (got these parts with the $100 transmission) , hard line, clutch pedal, flywheel, transmission wiring harness, and a few other things I can't think of off the top of my head
Stillen replica fiberglass front fascia, picked this up a while ago used, never got it painted or mounted on my car, not sure of fitment, has some stress cracks because it looks like someone did have it mounted at one point in time, I paid $140 for it
Call my cell - 727-772-3482 , my name is Dave
