S13/S14/SR20DET Huge Garage Sale!!
Old 08-02-2007, 11:12 PM
lifelong learner
Matt Vassallo's Avatar
Default S13/S14/SR20DET Huge Garage Sale!!
Jim Wolf Technology C1 Exhaust Cam. Wear on lobe #4 due to broken rocker arm issues. $30
S13SR/S14SR20DET Direct Fire Coilpacks. Nine Available. $20 ea
AEM/K&N 3" cone air filter. good condition. $10
S13/S14 5 Speed transmission crossmember with good condition transmission mount. These are getting harder to find and are requisite for swapping to 5 speed. $40
S13SR Valve Cover. Good condition. Paint this some crazy color like funk! SOLD
Z32 300ZX TT 30mm Iron Calipers. SOLD
S14 SR20DET Zenki MAF. with maf adaptor and intake hose. RARE! $80
S13 240SX Tail harness (speedo, alternator, starter, sensors, grounds, etc) and negative ground cable. $20
Complete T28 Upgrade for SR20DET. 1. Garret GT28R OEM S14/S15 Turbo. 1. 2.8mm equal length stainless exhaust manifold. 1. 80mm 2.8mm thick stainless steel turbine outlet. 1. oil supply line for GT28R. 1. oil return line for GT28R. 1. Oil return FLANGE for GT28R. 1. modified inlet pipe for intake with JDM PIE CUT intake for GT28R. 1. hotpipe for GT28R 1. SiliconHoses.com 2" coupler for specific hotpipe for GT28R. Everything here to bolt on to an SR and have 330whp. Do the math and see how much it would cost to get each piece separately, then add the time to get it all, shipping, finding everything, etc. Bolt it on in 2 hours with this setup. SOLD
S13/S14SR20DET Cam angle sensor. Great condition. Two Available. $80.00
SR20 Oil Pan Baffle. Replace your dented one. $10
S13 Rear multilink crossmember. Fix your car from that curb. $80.
S14 front lower control arms and spindles. Perfect for wider track on an S13, or replacing that Curb problem you had on your S14. helps you achieve additional drift angle, if that's what your after, as well as improved ackerman. $150 SOLD
S13 HICAS STEERING RACK - BALLERTOWN USA Quicker Ratio !!!! -SOLD
S13SR Complete Piston and Rod Assembly. EXCELLENT CONDITION 79E Pistons and Rods. $50 in rings and you're good to go!!! best budget stock rebuild ever - $60.00 or $20 per piston/rod
aim - thesocialmoth
email matt ology at gmail dot com
rest in peace tim.
Old 08-04-2007, 12:07 PM
Turn 7 at Sebring
RoadRacer's Avatar
bump for matt and some good prices!
Patrick -
Old 08-04-2007, 12:36 PM
Bo0st FTMFW
japanbran's Avatar
would you sell the turbo outlet seperate? ihave cash. pm me
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old 08-07-2007, 09:03 AM
lifelong learner
I would liek to sell the entire thing as a Kit, but if i can get everything sold i'll do that.
$75 for the outlet.
rest in peace tim.
Old 08-07-2007, 09:15 AM
Shakotan/Hippari life.
Ronald Mcdonald's Avatar
I would be interested in the turbo itself.
So maybe you can find someone for the manifold?
-'03 GSX-R 750
Old 08-07-2007, 09:27 AM
lifelong learner
The turbo ITSELF is $450.
rest in peace tim.
Old 08-07-2007, 11:46 AM
lifelong learner
Turbo setup is SOLD
rest in peace tim.
Old 08-08-2007, 08:48 PM
ALLEN P.'s Avatar
i want the pistont and rods 727 831 7478
Old 08-08-2007, 10:13 PM
lifelong learner
I'll give you a call tomorrow
rest in peace tim.
Old 08-09-2007, 07:28 AM
will mccullough's Avatar
matt i want your exhaust.. i know its not for sale but i want it! if you run across another one lmk thanx
