FS: usdm B16a2 block, acl bearings, hastings rings, misc
Old Apr 25, 2007 | 09:06 AM
boostedbastard's Avatar
Default FS/FT: usdm B16a2 block, acl bearings, hastings rings, misc
Up for sale is a used USDM B16A2 short block with 80k miles the block turns over and was working before pulled. i was intending to reduild it and put some civic type r pistons so i will include a complete bottom end gasket kit, acl bearings, and hasting rings (81mm). It also includes ARP headstuds.
you can have it all for 400!!!!
if you want just the block you can take it for 275
Old Apr 25, 2007 | 09:48 AM
Old Apr 25, 2007 | 02:25 PM
eksilver1's Avatar
rebuild
Old Apr 25, 2007 | 03:06 PM
Old Apr 25, 2007 | 03:08 PM
importeclipsegst's Avatar
so u where planning on rebuild cause it needs new rings? or does the block smoke?
Old Apr 25, 2007 | 03:11 PM
the block does not smoke or need a rebuild. i had some ctr pistons and i figured hey i could have a zero milage block with 11+:1 compression. but i have changed my mind.
Old Apr 25, 2007 | 03:12 PM
the cylinder walls still have the cross hatching
Old Apr 25, 2007 | 03:51 PM
Old Apr 25, 2007 | 06:31 PM
Old Apr 26, 2007 | 01:55 AM
