Testing Waters: Built LS block
Old Feb 14, 2007 | 03:06 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Thumbs up Testing Waters: Built LS block
Just testing to see what kinda interest is out there for the block currently in my car...
Block is a B18A1 block, I believe '93
Current bore is at 81.5mm
Has a NuFormz block guard that was professionally installed by Engine Lab of Tampa
All machine work was also done by engine lab
Has Eagle ESP HBeam Rods (the strongest ones with the bigger bolts) and CP 9:1 pistons (were actually 8.7:1 in my setup, so it does vary)
Rods and pistons were all balanced
99 LS b18b crank was also balanced and micropolished by engine lab
Assembly was done by myself using brand new type R oil pump and water pump
I used Clevite 77 bearings, as they utilize the same trimetal as the OE bearings
everything was plastigauged twice to be sure it is all within spec
This block is currently still in my car and running with about 20kmiles, and makes perfect compression all the way across...
I know I probably left some things out, so if you have any questions just ask...
Asking price is $1500 OBO
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 14, 2007 | 03:11 PM
Josh.'s Avatar
The Integra Guru!
Your an
You make broke people want to be rich.
04' Crystal White Lexus IS300
04' Premium White Pearl RSX-S
Originally Posted by 94lsteg
Old Feb 14, 2007 | 03:14 PM
Retired Ricer...
I wish I was rich too lol
Old Feb 14, 2007 | 03:21 PM
Josh.'s Avatar
The Integra Guru!
To the top for a nice Block!
Old Feb 14, 2007 | 09:14 PM
Retired Ricer...
thanks
up
Old Feb 14, 2007 | 09:19 PM
Eluzzionz's Avatar
just curious ..is this ur block u used for ur insaneturbo set up?...stock sleeves??
Old Feb 14, 2007 | 09:24 PM
Retired Ricer...
Yes it is the block currently in my coupe...
Old Feb 15, 2007 | 02:42 PM
Retired Ricer...
up for a solid bottom end
Old Feb 15, 2007 | 05:23 PM
THE_ONE's Avatar
*Turbo Interceptor*
I'm sorry Chris, but that seems alittle on the to cheap side. Did you get into some trouble or something?
Old Feb 16, 2007 | 01:30 PM
Retired Ricer...
nah i have some bigger and better plans for the car... as i said before, i dont really need to sell it i could just keep it for a spare, but i figured someone here could put it to good use...
