PasswordJDM- Oddesey pc545 Battery
Old Feb 14, 2007 | 02:26 PM
Josh.'s Avatar
The Integra Guru!
Default PasswordJDM- Oddesey pc545 Battery
Odyssey PC 545MJ Battery | JDM Honda Parts, JDM Honda Engines / JDM Nissan Motor Swaps, Used JDM Parts - Password JDM
Goes for $131.44
W/Shipping=140.44
It comes with the optional brass terminals
It has been used but for a short period of time.
Works perfectly.
Make offer's
Some fun facts for ya if you dont want to click the link.
The ODYSSEY® Drycell battery combines in one box the characteristics of two separate batteries. It can deep cycle as well as provide enormous cranking power.
These dry cell batteries are capable of providing engine cranking pulses in excess of 2150A for 5 seconds as well as 400 charge/discharge cycles to 100% depth of discharge (DOD). A typical starting, lighting and ignition (SLI) battery can do one or the other, but not both. Conventional batteries are either a sprinter or a long distance runner; An ODYSSEY® battery will do both — provide short duration high amperage pulse or low rate long duration drains.
PC 545MJ Specs
- 545 cranking amps for 5 seconds
- 495 cranking amps for 10 seconds
- 420 cranking amps for 20 seconds
- Short circuit current over 1200A
- 19 minute reserve capacity with 25amp load
- Female brass terminal w/M6 SS bolt
- With metal jacket
- Length 7.00"
- Width 3.37"
- Height 5.17"
- Weight 12.6 lbs
Features
- 2 year full warranty
- Rugged Drycell sealed design
- Military grade
- Vibration resistant
- 60% more starting power
- Deep discharge reserve power
- 2 year storage life
- 8-12 year design life
- Can be mounted flat or upright
Optional Brass Terminals only $9.99
- SAE Automotive terminals
- Brass Terminals
- Fits the Odyssey PC545, PC680, PC925, PC1200 and PC1700 series
- Universal terminal that can take either top post or side mount cables
- Compatible with standard automotive clamps and are threaded for a 3/8" bolt down the center
04' Crystal White Lexus IS300
04' Premium White Pearl RSX-S
Originally Posted by 94lsteg
Old Feb 14, 2007 | 02:30 PM
Josh.'s Avatar
The Integra Guru!
Happy V-day.
90 obo
Old Feb 14, 2007 | 02:47 PM
Josh.'s Avatar
The Integra Guru!
up for new info!
Old Feb 14, 2007 | 03:09 PM
Josh.'s Avatar
The Integra Guru!
Bump it up
Old Feb 14, 2007 | 03:44 PM
Josh.'s Avatar
The Integra Guru!
pm's have been replied
Old Feb 14, 2007 | 04:53 PM
Josh.'s Avatar
The Integra Guru!
up
Old Feb 14, 2007 | 07:14 PM
Josh.'s Avatar
The Integra Guru!
Old Feb 15, 2007 | 05:45 AM
Josh.'s Avatar
The Integra Guru!
Old Feb 15, 2007 | 09:53 AM
gsr corey's Avatar
i may buy it pm me your # and i will call you thanks
Old Feb 15, 2007 | 12:41 PM
Josh.'s Avatar
The Integra Guru!
PM'ed
