LS bottom end vtec ready ONLY 6K!!!!
ok first off it hasnt even been pulled yet and most likely wont be until the end of this month..im just posting up so i can have a buyer by the time its pulled...right now its still in my car and if ur a serious buyer and what to come and see the car thats not a problem..if u want..i will also take a down payment on the motor and have everything on paper and the day its pulled u can take it home..now the run down..
B18A1 block bored .25mm over
P30 Jdm B16 Pistons .25mm over (i messed up here i put pr3..but i meant p30..they are jdm b16 pistons which will yield a higher compression)
Ls connecting rods with Arp Rod Bolts
Ls Crank
Vtec oil and water pump
All OEM bearings/seals etc
everything inside the bottom end was new excluding crank/rods..
the crank was polished before installation..
there is only 6000miles on this swap and has been fed only mobile1 fully synthetic oil...it runs very strong and should yield a compressiong of 11.56:1 with a b16a head..
this would be great for anyone with a b16a that wants an ls/vtec set up..all ull need is to tap head and get a gsr timing belt and bolt on the cheapest hp u can find..taking ur lowsy 130-40whp up to 185whp+ with this bottom end..im asking 600obo..NO TRADES!
Ls Crank
i really need cash to finish turbo setup...the bottom end will be most likely taken out at the end of the month...i just need to get money to get my car in the shop and finish it...IF..ur willin i will write up an agreement...ill take the money and have the car put in the shop..the motor will be out that day or the next im not here to rip any one off and i can be trusted with this..the car will be going to 2nrwerks as soon as i get the money for them to start working on the car..and they plan to take the bottom end out ASAP so i can sell it...so if u want to go through them that is perfectly fine..u can pay them get a receipt and as soon as the motor is out u can come pick up the block..just lmk guys..the sooner i get money the sooner i can get this block out....just lmk what u wanna do..
