only 7psi???
Professional Asshole
on
only 7psi???
so i finally got my boost gauge in my wrx that i bought a 2 monthes ago and its only at .5 bars (about 7psi) i thought the stock was 14.7????? Does anyone know why this is???
Semper Fi
Aim and Yahoo- Inkedupordie
Semper Fi
You probably have a kink in the line or your fittings are not tight.
'02 Subaru WRX 2.5L, SR40 turbo, MRT TMIC, RA gears, ACT clutch & flywheel
'06 Chevy Cobalt SS GM Stg 2 G85 lsd
'94 Acura Integra GSR sold
'99 Isuzu Rodeo 4x4 2" lift, Procomp 9000 shocks, 20" Procomp Knight Khrome wheels sold
'92 Acura Integra RS sold
'04 CRF450R '86 TRX250R
or if you have the same problem i did....the pill inside the t-connector hoses is pinched a little bit or completely. another area i leaked a little boost was because of the bov. check all lines and connections and like im slow said which gear are you pulling it in?
on
i tried all gears, only one that hits .5 is 4th and 5th the rest r just under. i just checked all my fittings and nothing, and it ran the same boost w/ the stock recirc. valve as the bov. could it be the thing next to the airbox that the vacuum tube goes to and the other one that goes into it goes to the intake pipe
Semper Fi
Semper Fi
on
what pill in the t connector r u talking about black. i tried reseting the ECU, i checked all the lines none
Semper Fi
Semper Fi
on
i'll check all the lines again if not i guess its a trip to subaru.... it sucks b/c thats a 2 hour drive... i hate north carolina
Semper Fi
Semper Fi
on
i had one for my gas cap, i replaced it but it came back on about 50 miles later. i dont think that has anything to do w/ it.
Semper Fi
Semper Fi
