FS: 128.1 whp Z6 SOHC + JDM ZC Trans
95 D16Z6 was tuned by me at Secret Services
IDEALLY for EF CHASSIS
EG/EK CHASSIS WILL NEED HYDRO TRANNY and New CLUTCH DISC
128.1whp@7400 and 103.0tq
Stock 9.5:1 compression (decent for boost)
JUN cam gear
Skunk2 Intake Manifold
60mm LS TB
Aem Fuel Rail
Marshal Liquid FPR Gauge
JDM ZC oil cooler
Beck & Arnley 180 Degree Failsafe Thermostat
Chikara Header 4/2/1 (Bert-0 PM me)
98-00 Honda SOHC valvecover
OBD1 distributor
JK OBD0-OBD1 conversion harness
P28 ECU
NGK 8mm Wires
NGK BPR6ES Plugs
1 OFF Full Polyurethane Engine Mounts
Waterpump
Timing Belt
Gaskets
less than 7k
Block/Head/Valve cover Hand Polished
88 JDM ZC transmission
JDM ZC half shaft
SPEC Stage 3- 4puck disc
Exedy Dual Diaphragm Stage 2 pressure plate
ACT 7.5lbs Racing Flywheel
Extras-
Custom TURBO Schedule 40 Stainless Log Manifold w/ T25/14b DSM flange
DSM blue top 440cc injectors
Aeromotive Boost FPR or SARD Boost FPR
FUN SETUP FOR 300whp under SOHC Boost
$800 obo
everything is in Largo
JUN cam gear
60mm LS TB
Aem Fuel Rail
JDM ZC oil cooler
OBD1 distributor
P28 ECU
NGK 8mm Wires
NGK BPR6ES Plugs
Waterpump
Timing Belt
Gaskets
less than 7k
JDM ZC half shaft
Extras-
$800 obo
So is this thing N/A or boost? Im a lil confused. And how much w/o the turbo stuff?
Bert-O - I saw you driving on 275 south probably coming from LHT..still got the bubble bee huh? lol Ive just been finishing up school ...not messing with cars too much
You can do N/A or Boost up to you...Im throwing in the Turbo Stuff for Free
There's almost $800 in the tranny parts alone
Speaking of the tranny? I thought it wasnt possible to mate the ZC tranny to our USDM SOHC? I guess you did, just something new to me. Are there any benefits in running that tranny? And are parts easy to locate?
way better gearing
each gear is shorter 1-5
however 3.8 final
with an SI final drive tranny would be absolutely sick! 4.2 ( i think)
you can hybrid an SI/ZC tranny for the ultimate tranny so parts from SI and ZC are interchangeable
The Rpms drop roughly 500-700 rpm per gear...its pretty sick good for town but crazy for highway
Also Half shaft setup is great for less to no torque steer commonly associated with Sohc uneven axles setups
I mix n matched clutch parts in order to run the larger 212mm on the 88 tranny
however 3.8 final
