Poor Mans Itr Swap****look****
- :d B-out K-in 1.9 Stroked Gsr Swap:d
bottom End
96 Gsr Block
new Ls Knife Edged Eagle Crank
arp Main Bolts
gsr Girdle
new Ls Eagle Rods
all New Acl Bearings Mains,rods And Thrust Washers.
new Je 8:8.1 Dishtop Turbo Pistons With Arp Rod Bolts
new Npr Rings
new Itr Oil Pump
new Water Pump
new Timing Belt
tapped Gsr Oil Pan
new Oil Pick Up
head
99 B16 Civic Si Head
b16 Intake Manifold
stock B16 Exuast Manifold
1.8 P72 Gsr Cams With Stock Cam Gears
obd1 Brand New Distributor From Honda
with Msd Cap,rotor,external Coil
gsr Fuel Rail With B&m Fpr And Gauge
tranny
s1 B16 Tranny
act 12lb Flywheel New
act Xxxtreme Pressure Plate New
act 4 Puck Unsprung Clutch New
b Series Axles
manual Half Shaft
b Series Ef Shift Linkage
ef B Series Solid Swap Mounts
comes With Msd Sci Ignition Box
ecu
p28 Obd1 Vtec Ecu
socketed By John Vaga
91 Civic Si Harness With All Obd1 Plugs Needed On It Already
asking Price........$3000.00 Obo
call Me For Details 727-565-6627
UPDATE>>>>10/26/06
just so everyone knows this motor has maybe 100 miles on if that i drove it to work for three days, pulled it out. and sold my shell and turbo kit. motor has been sitting for three months. sold my gsr head and bought the b16 head to sell it as a hole swap so this buttom end is pretty much brand new.
MOTOR IS SOLD AS IS!!!!!!
Best Honda Slogan Made By Greg
"Ur Boosted B series
Dosent Have A Chance
Agianst My K On Spray"
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
Pablo 'Fathead' Garcia
Always will be remembered!
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
im asking 1500 obo for just short block. thats oil pan to the deck. make me a cash offer . thanks
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
thats what the pistons are rated in a gsr its a little higher with b16 head like 9.1
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
thanks boys for the bump
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
up
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
B SERIES
D SERIES
AIM : Goodfellas727
R.I.P.
