WTT 90 4x4, for rwd
Old Oct 2, 2006 | 07:54 PM
matrixminded84's Avatar
Im over it
Default WTT 90 4x4, for rwd
I have a 1990 ford f150 4x4 for trade or sal, i have a whole list of new parts, The engine is out of a 1995 ford f150 with approx 58,xxx miles on it, the body and frame have 115,000. The motor does not smoke or knock, new distributor, sensor, plugs, wires, oil, oil filter, valve cover gasket, oil pan gasket, new starter sylenoid, starter, fuel pump, fuel filter, i just had the injectors cleaned. Clutch has close to 2600 miles on it, and i just replaced the throw out bearing. The truck has a 3" body lift, and 35" tsl swampers, 2 tires and rims are different because someone decided to steal the back 2 t/r's. In the back, there is a 4x6 solid steal rear bumper welded and bolded to the frame, altezza lights,tool box in bed, and trailor lights plug. The interior is very clean, no scratchs or cracks on dash, custom paint, oil pressure/water temp guages on piller. There is a 80watt amp hooked to 2 6x9 in the door, and there are 6" in the door also. I am removing the cd player. The seat has minor rips on the driver side. All work on the truck i did, i know this truck is mechanically sound. Truck needs tranny, and i know were there is one for cheap. I know whats in the truck, and i know that it will get you to any mud hole and get you home. pics are in my garage
Im looking to trade for a second gen running rx-7 - modded or not
Or a running MK2 supra - modded or not
Old Oct 2, 2006 | 09:52 PM
Im over it
Old Oct 3, 2006 | 04:38 AM
Im over it
morning bump
Old Oct 3, 2006 | 03:03 PM
Im over it
Old Oct 4, 2006 | 05:51 AM
SkwervE's Avatar
realer than most
how much cash? and do you have any pics?
Old Oct 4, 2006 | 02:56 PM
Im over it
pics are in my garage, and im asking 1800
Old Oct 6, 2006 | 12:21 PM
Im over it
Old Oct 14, 2006 | 05:16 PM
Im over it
Old Oct 28, 2006 | 06:20 AM
Im over it
just put an oil change, rotate, balance, and a full tune up on the truck.
Old Nov 6, 2006 | 06:53 AM
Im over it
