F/S 300whp s14 sr20det
For sale is my 98 s14 sr20det motor and tranny.
what comes with motor=complete motor set. meaning everything you need to get the motor running, power steering pump, alternator, turbo, and the sr a/c braket was modified to work with ka a/c compressor so that you don't need to modify the a/c line. just use you existing a/c line and charge it up.
performance upgrades= garrett gt28r BB aka s15 turbo i bought brand new about just over a year ago from ATPTURBO.COM. rare hks internal waste gate actuator. greddy rocker arm stoppers. megan racing turbo mainfold. ACT street/strip clutch that has less than 1.000 miles on it. blitz 550cc injectors. Q45 90mm maf with plug already wired to the harness.
note= the harness is already done for a 96 240sx so do you research. i had to run a switch to the fuel pump because it would only purge for 2 seconds and shut off. im not sure if thats a ecu problem or something else. it is a late model s14 sr and the ecu says N/A on it. it does not have a turbo outlet pipe so you need to get one. you can find those anywhere for cheap or just go to ebay and get a aftermarket one. motor was sitting for a year in my garage.
motor has no problems and runs very strong. i only put about less than 5.000 miles on it. it had 38.000 km on the odomiter when i got it.
DON'T MISS OUT. THIS IS A DEAL OF A LIFETIME.
It has about $1,800 or more on performance parts alone. I am asking $4,000
for everything. if you want it installed in your car i will do it for an extra $500.
if you have a complete ka motor to trade i will sell you the motor set for $3,800. if you want it installed with a ka trade i will do it for $4,300.
PM ME IF YOUR INTERESTED.
good deal fast,cheap, and easy lol good luck with the sell.
www.Fabthis.com
Check out our blog and buy our products
Prestige Worldwide ... Wide..Wide....
www.Fabthis.com
