FS: Blitz SBC-iD dual solenoid boost controller & Power Meter-iD
Old May 2, 2006 | 10:11 AM
TampaStig's Avatar
AEG
Default FS: Blitz SBC-iD dual solenoid boost controller & Power Meter-iD
SBC-iD Boost Controller
$400
Boost Unit - Boost can be displayed in standard and metric measurements (PSI, bar, kPa, and kg/cm2)
Four Channels - Has 4 different programmable boost settings.
Boost Gauge - The SBC i-D can display boost in digital and graphical form.
Peak Hold - SBC i-D can record the highest boost achieved by the vehicle.
Boost Warning and Limiter - This is a safety function that allows the operator to set the amount of boost decrease in the event of over boost. Warning is in both visual and audible.
Manual or Automatic boost setting - The SBC i-D allows the user the choose how the boost is set.
Manual - Sets boost in ratio, from 0-100. By using the manual setting, this allows the boost controller to give maximum boost response.
Automatic - Sets boost directly, just dial in desired boost amount.
Record and Replay- SBC i-D has the ability to record and replay any information up to 99 seconds. The SBC i-D can also record and replay information on the Power Meter i-D and Optional Data (Power Meter i-D and SBC Optional Harness required). Replay can be fast forwarded and replayed in 2x and 5x.
This is the most advanced boost controller available from Blitz and uses a twin solenoid set up for better response and holding high boost pressures. Maximum controllable boost is 2.5 bar (36.75 psi).
Power Meter-iD
$200
The Power Meter i-D measures and displays on the in built LCD screen the vehicles power and speed. Horsepower (HP, PS or kW) and speed (MPH or KMH) can be displayed in both graph and numerical form. The Power Meter i-D also has a Chassis Dyno Function which plots HP to speed in a graph form. The power meter also times 0-1/4 mile times and other time and speed targets. The Power Meter i-D is available for most makes and model of vehicle, turbo and non-turbo, as long as they have a speed sensor. It is very easy to connect with just 3 wires needing connection. The Power Meter i-D is 1/2 din size and is mirror image of the SBC-iD so they can be paired together (see picture above). Comes in silver of black to match the SBC-iD and other Blitz products. When linked with the SBC-iD the Power Meter i-D enhances the functionality of the SBC-iD.
BOTH FOR $575 SHIPPED
**info taken from Blitz website**
Originally Posted by shinmei2006
if you want to have fun get the s2k, if you want to go fast in a straight line but get made fun of in everyday traffic, get the srt4
Old May 2, 2006 | 01:52 PM
TampaStig's Avatar
AEG
Old May 2, 2006 | 06:20 PM
TampaStig's Avatar
AEG
ttt.........
Old May 2, 2006 | 08:58 PM
TampaStig's Avatar
AEG
Old May 3, 2006 | 10:30 AM
TampaStig's Avatar
AEG
Old May 3, 2006 | 03:54 PM
TampaStig's Avatar
AEG
iull ykhpjp
Old May 4, 2006 | 03:24 PM
TampaStig's Avatar
AEG
Old May 5, 2006 | 07:58 PM
TampaStig's Avatar
AEG
luiyf
Old May 7, 2006 | 07:00 AM
TampaStig's Avatar
AEG
uykhf
Old May 9, 2006 | 06:30 AM
TampaStig's Avatar
AEG
