tw... wtt fully loaded mechanics tool box for b-series
Old Apr 30, 2006 | 11:05 AM
si0385.'s Avatar
jdmasfuk
Default tw... wtt fully loaded mechanics tool box for b-series
tool included:
13mm-27mm 1/2dr. deep impact socket set husky
10mm-27mm 1/2dr. shallow impact socket set Mac
T10-T60 torx reg style Mac
T10-T60 torx new style Mac
10mm-19mm 3/8dr. impact swivel Mac
adapter set (mostly mac) includes all even 3/4 ->1/2
10mm-22mm 3/8dr shallow impact socket set Mac
8mm-21mm 3/8dr deep impact socket set Mac
2ft pry bar Mac
42in pry bar Mac
1/2dr breaker bar Mac
Misc bolt drawr (lots of h/a bolts)
mini screw driver set
shrink wrap
electrical tape
center punch / scribe
4 misc allen key setes mis brands and mis allen keys
4 tire guages
a squeegee for tint/vinyl
markers
misc air impact fittings
screw driver drawr... has just about everything... snap on, cornwel, mac, stanley, craftsman mostly
mac pick tool (most handy thing ever)
SK wrench set 10mm-22mm and an adjustable wrench
1/2dr craftsman ratchet
1/2dr craftsman breaker bar 14inch
titan 3/8 1/4 stuby ratchet
no name 3/8 ratchet
2 craftsman 1/4 ratchests
3/8 snap on ratchet
3/8 mac ratchet long handle
all extentions included 1/4 3/8 1/2 1inch 3inch 6inch 9inch yada yada
2 noname crimp tools and wire ends
blue point crimp tool
8mm-19mm flex head ratcheting wrenches bought from mac tool truck
wire stripping tool
mac test light
misc fuess
diaeletric grease
contact cleaner
noname test light
ground straps power wires 4 awg 8 awg
a/c filler hose
brake caliper hex head set
4mm-15mm 1/4dr SK shallow socket set
6mm-15mm 1/4dr SK deep socket set
1/4-9/16 deep 1/4dr SK
3/16-9/16 shallow 1/4dr SK
10mm-18mm 3/8dr deep SK
6mm-19mm 3/8dr shallwo SK
belt tensioner tool
1/4-7/8 3/8dr shallow SK
3/8-7/8 3/8dr deep SK
than a couple of mis sockets
3/8 and 1/4 drive swivels
all are on mac magnetic trays
mac ball peen hammer set (6 ball pean hammers)
spark plug wire puller plyers mac
door pannel poper plyers mac
misc plyers 6inch 8inch
channel lock plyers mac 12inch 16inch (huge used for compressing calipers)
needle nose vice grips
regular vice grips x2
cutting dikes channel lock brand
needle nose plyers channel lock brand
c clamp 6inch
Axle nut socket set Mac 1/2dr 29mm 30mm 32mm 34mm 35mm 36mm 38mm
brake took kit (drum brakes) mac
safty glasses clear
spring compressors
blow gun mac
3/8 impact gun mac
die grinder mac
3/8 air ratchet husky
1/2 impact gun husky (500 ftlbs actualy more powerfull than the couple of mac guns ive tried)
2 tire chucks
coolant system pressure tester Mac (comes with honda adapter)
p/s pulley puller kit Mac
jack stands
oil drain
chain with bolts for breaking ball joints and lowering control arms
o2 sensor socket
spark plug sockets
like the title sais i want to see if anybody wants to trade this tool box for a b-series swap, i have easily put over $4,500 in this tool box (in fact i still owe $2,200 on it) so i dont just want to trade a b16 short block for it, im looking for a FULL SWAP and it has to be b-series dohc vtec (no ls/b20) i might concider a ls/vtec if i trust the person who put it together... with the full swap i also need mounts and shift linkage ecu...
i know i can get a prety nice swap for 4500 but i also know i will be taking a huge cut in this trade so im looking more towards a gsr/type r/b16b with any luck
i might take a good running b16 with alot of other goodies (seats, harnesses, trac bar, steering wheels, maybe a set of good wheels) but keep in mind this is going in my daily driver so i need reliability so preferably no swaps that were sprayed or boosted
Old Apr 30, 2006 | 03:01 PM
si0385.'s Avatar
jdmasfuk
Old Apr 30, 2006 | 05:49 PM
si0385.'s Avatar
jdmasfuk
c'mon guys b-series are a dime a dozen its not every day you can trade one for a 5 thousand dollar tool box
Old May 1, 2006 | 02:33 PM
si0385.'s Avatar
jdmasfuk
Old May 2, 2006 | 12:38 PM
Ef9Hatch90's Avatar
bump for a good deal
Old May 2, 2006 | 05:23 PM
si0385.'s Avatar
jdmasfuk
Old May 2, 2006 | 06:40 PM
91EF-9's Avatar
is tired
i have a b16a i know you said b16b but im throwing up at ya its got a brownish gold valve cover came out of my ek
bucs2superbowl03@yahoo.com
Old May 3, 2006 | 03:30 PM
si0385.'s Avatar
jdmasfuk
i would concider a full b16 swap and SOME cash.. you gota understand how much money i have in this tool box no offence or nothing but it would be like paying 5k for a b16a
i would also concider some other goodies for a crx if you have any
Old May 3, 2006 | 05:40 PM
si0385.'s Avatar
jdmasfuk
Old May 3, 2006 | 06:16 PM
91EF-9's Avatar
is tired
how much cash on top? what kind of stuff are you looking for, for the crx? lmk thanks
