***97 SER with SR20DET (BLUEBIRD)****FS/FT
Old Jan 31, 2006 | 12:49 PM
cullyboiracin's Avatar
Default ***97 SER with SR20DET (BLUEBIRD)****FS/FT
This is a Red 97 Nissan SER
-The Bluebird swap was done by Andros Miko from Supreme Foreign Auto
has about 43k miles from me and the last owner.
This is my daily driver, so i leave the low boost on 7psi and high is on 9psi.
CAR IS IN ORLANDO FLORIDA
INTERIOR
-Stock b14 seats in mint condition no rips tears, etc...(in front or back)
- type r shift boot
- MOMO shift nob Cut shorter and rewelded...it does the job.
- redone headliner ( look @ pics)
- JVC dvd headunit sick head unit can play iPod with Aux input...
- Screen is mounted on passenger side
- car was redone with Polk Audio components (crossover and mids and tweeters)
- i have 2 pioneer subs with a custom inclosure but no amp but the amp wires are in place. all you need is an amp n your good.
- Greddy Turbo Timer n Boost Controller w/ steering wheel switch.
- Carbon Fiber Air/Fuel gauge (not very accurate without wideband)
- Spearco Boost gauge
- NO AC. HAS P/S .
- Sunroof
- The horn inside the car does not work (for the alarm it does tho)
- Stock alarm works fine...has the thing where if alarm is tripped, and someone tries to disconnect battery when reconnect the alarm will still go off.
EXTERIOR
-Stillen Front Fascia
- RevHard Stage II wheel 17" all around with 205/45
(fronts have 70% rears 85%)
- Wilwood Big Brake kit. 4 piston in the front with 11" slotted n drilled rotors. 2 piston in the back with slotted n drilled rotors also.
- Steel braided brake lines all the way around also.
- KYB AGX adjustable shocks
- Matted with Ground Control Coilovers
- STILLEN Strut Bar
-paint is in perfect condition (never repainted)*the back bumper has a lil chipping from the sun*
-15% tint on driver window (passenger window was smashed and i havent gotten to retiniting the new window)
-The hood is black not CF
- Transparent red painted taillights loks alot better than OEM
- Blacked out headlights and clear corners
-Battery relocated to Trunk
MOTOR
- A BLUEBIRD SR20DET *not a turbo sr20de*
- FRESHLY REBUILT T3/T04E turbo by Nossle Masters (installed as of 11/20/05)
- oil changed ever 2500miles same for tranny
-Has JWT ecu tuned for the specs of the car.
- Emanage (installed as of 12/28/05)
- Apexi 4" Carbon Fiber/ Burnt Tip exhaust replica sounds fine
- 3" piping all the way back
- Forge front mount intercooler and BOV
- Powder coated Intercooler piping
- 300zx MAF
- MSD 50LB injectors
- JWT fuel rail
- Aeromotive FPR
- JWT 4 bar turbo program
- Walbro 255lph Fuel pump
- TIAL 35mm Wastegate (no dumptube)
-NGK plugs BKR7E. gapped .024 there a bit hotter than normal plugs
TRANSMISSION
- SR20DE Transmission
- Cryotreated gears and shot peened by last owner
- Exedy Stage III clutch. Cerametallic Clutch with HD Pressure Plate (installed as of 1/31/06)
-Fidanza 8.5lb Flywheel (installed as of 1/31/06)
THINGS TO GET CHECKED AND FIXED
- Passenger window needs tint
- If you love boost you better love gettin gas to..thats all im sayin (good on gas otherwise)
- Car is sold as is...NO WARRANTY
$7000 OBO (will consider some trades)
*oddly im looking for my car in a rwd form with a similar build just want a rwd cuz i never had one.. i would also like a awd but dont think people are will to trade one for my car...95' 240 5spd with maybe some nice wheels
cell (321)278-7053 or PM
(please pm with trades or cash inquires) (not about where i got my short shifter and or intercooler piping, etc...) THANK YOU...
Old Jan 31, 2006 | 01:45 PM
Signal7cbr!'s Avatar
hates change
as a b14 i owner i give you props on such a nice car.
if i had 7k id scoop that thing off of you in no time.
unfortunatly alls i have is a slightly modded b14
good luck with the sale or trade.
as well a bump for a good looking car
Originally Posted by b16sleeper
don't worry...if i see a white guy with an afro...i'll yell crackhead and watch the cops tackle you before you touch me..
Old Feb 1, 2006 | 09:14 PM
bumpsicles
nissans the way to go...............fast that is
Old Feb 10, 2006 | 08:50 AM
best offer of 6800 so far....
Old Feb 20, 2006 | 10:33 PM
bump for a quick victory...
05' Evo MR (boost controller and walbro fuel pump)
2nd gear roll...
pulled a car in the middle of third on 13psi...
any buyers now....hahhaha
Old Feb 22, 2006 | 05:02 AM
VoidDweller's Avatar
TR Balla Donor Supreme
nice car
_____________
_______
04 TSX
97 240SX SE (SR20DET)
PM if you need B14, S13, KA or SR parts
http://www.engrish.com/
Old Feb 25, 2006 | 01:27 PM
it is just got a greddy grex shift knob and new brake pads
Old Feb 25, 2006 | 05:03 PM
4dorteg's Avatar
Allan works as well
pm me if you still have stock sr-20
TR salesman..........
