90' Civic HB Drag Car Rolling Chassis
All you will need is Engine, Tranny, Axles, Ignition, and Engine Management or Stock harness. I have a modified harness that will come with the car.
Vehicle includes:
MB Products 1 piece front end
Bogart 13x8 and 15x3.5 Super Dragonflies
M/T 24.5x8x13 and M and H Skinnies
Extra Slicks 24.5x7x13
Custom Chromemoly Rear Straight Axle w/ CNC Hand Brake
Custom Front Cross Member
Custom 6 point Cage
Custom Tin Work in Back, on Doors, Dash, And Wing
Koni Shocks and Skunk2 Coil-overs
6 Auto Meter Gauges Tach, Volts, Water Temp, Air Fuel, and Oil Press and Temp
Custom Switch Panel
Momo Steering Wheel w/ Wheel Disconnect
Lexan Windows
Kirkey Race Seat w/ 5 Point Harness
Aeromotive Fuel Pump, AEM Race Fuel Regulator, BG Fuel Filter, Fuel Rail, Fuel Lines
Jaz 1 gal. Fuel Cell
Radiator w/ Catch Can
Moroso Oil Catch Can
Motor Mounts for B-Series
Shift Linkage
Setup for Hydro Tranny w/ Master and Slave Cylinder
Custom Traction bars
Color is Orange Inside & Out w/ Black Cage & Tin Work
Price is $3500 OBO SOLD
I will also sell everything I have to build a motor for the car. Plus Tranny, Racing Axles, the Chassie, and all my extra parts for $5000 or make offer.
Tranny For Sale: 00' SI Hydro Tranny w/ Pro Drive Spool & Stock Diff. $700 OBO SOLD
B20 Block and Crank, Eagle H-Beam Rods, and Custom JE Pistons 85mm 14:1 using a B16 Head $1000 OBO
93' B16 Head Milled 40 Thous. Ported Int. and Exh. Has Ferera .5mm Over Valves, Crower Springs and Titanium Retaners. $700 OBO
Email is Hgibney@cfl.rr.com
Phone # 321-258-9891
[[img]null[/img]
Vehicle includes:
Custom 6 point Cage
Custom Switch Panel
Lexan Windows
Shift Linkage
[[img]null[/img]
I can't give u a price running because I just don't have and time to build another motor for it. But I do have the part to build the same motor that I had in the car. The car ran 11:53 et @ 119 mph w/ a 1.53 60 ft on gas w/ an obd 1 ecu. I put a FAST engine management w/ Alcohol picked up some mph but still needed to be tuned. If you are interested make an offer I will sell everything I have.
