1991 chevy ex cab dropped...
Old Jan 3, 2006 | 05:23 PM
dsmtuner's Avatar
gotta love the boost
Default 1991 chevy ex cab dropped...
O.k. Ive got a 1991 chevy s-10 for sale extended cab, im selling it because it has some internal problems on cylinder #1 possibly a wrist pin come loose, or maybe a piston. Truck ran strong before it dropped a cylinder. Here is the list of mods.... truck does not have a spot of rust anywhere.... and has an h.p. 4.3
Body
92 z-28 camaro rims
Dropped in the rear 4 inch blocks 3 inch eibach kit in the front.
fiberglass cowl induction hood
acura integra seats bucket seats mounted on the s-10 frames
new carpet (molded)
monster tach
a pillar 3 guage pod
Drive train
msd 6a box
blaster coil
brass cap and rotor
twin electric fans
new radiator
new water pump
comp racing cam 500 lift, 225 235 duration
stainless valves 135 lb valve springs exhaust valve oversize to 165
new starter
holley 670 cfm tbi
edelbrock tbi intake , ported to 52 mm to match the tbi
chrome air cleaner with k&n filter
new distributor
new flywheel
new clutch
new slave cylinder
new master cylinder
5 spd transmission out of z-28 camaro 17 degree tilt
New u joints
complete new rear brakes, drums shoes, hardware (bendix)
diff is 373 LSD eaton center chunk, yukon gears
hedman long tube headers with 2.5 inch true dual exhaust running all the way back with an h pipe.
Nascar ignition wires with ceramic boots resistant to hedder heat
edelbrock performance chip
I know there is more but i cant remember.....
Ill include a completly dissasembled short block with all thats needed
I have a ton of cash in this ride. Im selling it cheap, just for what was in the motor, and trans swap the heads alone have 800.00 in them. Its painted white, good clean shine, no overspray, has a few drips that could be removed with wet sanding. The body is clean, and the A/c even blows ice cold, almost everything has been replaced..... This truck stood tall with V-8s and was a sleeper, h.p extimated between 250-280 I have reciepts for all engine parts, and most other new parts
I would like to get 3,000 out of it, i think that is fair, you couldn't buy the aftermarket parts on it for that much
I WILL NOT PART THE TRUCK OUT... Sold as whole only
I will take offers, But if you think youll get it for 1,000 itll never happen...
truck is clean..... message me , let me know, if i have enough interest i will post pictures..... otherwise i wont go through the trouble
Pete
SVT F150
Old Jan 3, 2006 | 05:45 PM
dsmtuner's Avatar
im bored
TTT
SVT F150
Old Jan 3, 2006 | 05:54 PM
dsmtuner's Avatar
Default update, truck still runs, not locked up, 30 psi on # 1 damaged cylinder
update, truck runs not locked up, 30 psi on number 1 damaged cylinder left that out of the thread.
SVT F150
Old Jan 3, 2006 | 06:05 PM
dsmtuner's Avatar
trades will be considered, have something?? let me know...
SVT F150
Old Jan 4, 2006 | 02:17 PM
dsmtuner's Avatar
SVT F150
Old Jan 4, 2006 | 02:52 PM
Paul's Avatar
Motha Fawking Baby Maker
I would buy all your drop parts....
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Jan 4, 2006 | 02:55 PM
conlyn's Avatar
Resident User
post some photos
Old Jan 4, 2006 | 05:25 PM
dsmtuner's Avatar
Default I wont part truck
its not worth my time to part out the truck, sold as whole only....
SVT F150
Old Jan 4, 2006 | 06:05 PM
dsmtuner's Avatar
picture of truck maybe?? does not seem to be working.... as soon as i figure this out i will post a few...
SVT F150
Old Jan 5, 2006 | 07:14 PM
dsmtuner's Avatar
SVT F150
