How much for ARP Rod BOLTS n ARP HEAD STUDS?Rep points given
REP POINTS GIVEN i am doing ls/vtec in my 00 si and i am putting a 93ls block w/ my 00 B16A2 Head and i need ARP Head Studs And ARP Rod Bolts
got B16 ARP studs on Ebay for 41.00 new but got very luck. 115.00 is about the best you can do on ebay deliverd cost to your door. LS ARP bolts are small and thus less than b16 and b18c so look at about 34.00 to 38.00 for those
i have a set of brand new Ls rod that is heat treated, fully balanced, shot peened, arp rod bolt and it is hooked up to jdm b16 piston with brand new nippon rings never used. If you are looking to build an ls/v these would save you a lot of hassel. Pm if you are interested
thanks
thanks
this forum is for selling parts not asking questions. thank you
- The Spectacle
- The Spectacle
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
