All Mota Killa F/S!!! Must see!
B18B .030 over
GE Block guard installed before align bored and honed
wiesco half skirt super light 549gram (11.8:1) tool steel pind with the half skirts coated and piston tops bead blasted. 1mm topring Darton replacement sleeves
Crower pro-billet rods with ARP bolts
Crank has been knife edged with oil gallies champhered, micro polished and re balanced for 10K rpm with flywheel and balancer installed. Rods have been sonic tested, everything balanced (static)
Pan, pick up etc..
As for the head it's a b16A2 with ferrera valves, stainless, tapered swirl polished FI. Ferrera springs, retainers and guides. five angle and civic R cams ARP headstuds and cometic stock thickness 82mm gasket. in the box. Studs are installed. For those of you who don't know with head with the pistons should put you up to 12.0-2~ This has been a two year project to get all this done and have more than 4K invested plus receipts for everything. 3500 obo takes it...
If you look please bump.
Pan, pick up etc..
Check the reverberating carbonizer for helium expansion.....
weak sauce! why you are selling? I thought this was going to be the alcohol breathing monster?
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
