Brand New Rsx-s Spec Stage Ii Clutch And Flywheel
Brand Spanking new SPEC Stage II Kevlar Faced Clutch for sale for an RSX Type-S. The SPEC Aluminum flywheel has less than 8k miles on it. If the clutch is used in combination with the flywheel it will work on a base model as well! This clutch has the smoothest engagement of any clutch for the RSX! Great for forced induction or high na applications!!
GO: Cybernation Stage I Turbo Kit w/ Guardian E.I., Tanabe Sustec Pro SS Coilover System, Greddy SP2 Exhaust, SPEC Stage II Clutch, SPEC Aluminum Flywheel, Revo Adjustable Short Throw Shifter, Greddy Profec B-Spec II Boost, Controller, Brembo Drilled Slotted Rotors, Russell Stainless Steel Brake Lines, Axxis Metal Master Pads
SHOW: JDM Headlights, JDM Side Markers, JDM Wing, Exel Madrid Rims w/ Ventus 215/45-ZR17 Tires, Type-R Lip Kit (awaiting install)
Ill take 650 Shipped for both of them! The clutch is 500 new and the flywheel is 380.
if you will do 600 shipped let me know and ill get with you and send you a money order asap
07 X-Runner
TRD SC- 7 PSI 342 whp 360 tq
DJM 3" drop up front
SS sways front and rear
custom 4 link with QA-1 coilovers w/300lbs springs
Ipad in the dash.
Grip or Bust.
07 X-Runner
Ipad in the dash.
Grip or Bust.
buyer backed out...BUMP!!!!!!!!
