Uberdata?
go on google type : unofficial uberdata mirror, and all the info you need will come up.
then actually talk to people who have/had it and see what they say........
I tossed it for hondata, and thats all i will say right now
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Here is some info on how to use it
http://superhonda.com/tech/honda_ecu_programming.html
Uberdata is free get yourself a copy online!!!
Broke People use Uberdata............. (inside joke before anyone takes toooooo much offense)
I am gonna run Hondata on the new setup.
Green Eyed Princess Lover
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
here is my laundry list for uberdata: before anyone gets all butt hurt and cries-
pros:
-uberdata is virtually free
-it uses fairly inexpensive, and readily available chips
-idles pretty good size injectors, up to 880cc+
-works well on the stock map
-uses same romulator/programmer as hondata
-has some decent features.
CONS:
-only works on "some" ecu's
-has some bugsin it still
-datalogging looks like a 3 year old drew the lines, and is slow
-cant support a large map sensor
-cant calculate fuel above 12psi
-cant full time romulate
-files become corrupted easily and dont work
-fuel multiples are off and must be corrected by hand
-too many versions ie: 1.6,1.66,1.666666,1.6woot woot,1.7,1.7beta
all in all if you have the time to play with it in a car, it could be worth it, i needed something a little more user friendly, many people have made mad power on it. yet have made it slower than other systems. certain functions are ther but dont work, big issue.
pros:
CONS:
owner/operator
owner/operator
I personally run the latest version of UD ( 1.8 ) And I have no complaints... My car ran awesome until it blew... The only possible thing I can think that I want to look into is the boost cut.... Everything else is fine, and all the features work fine now.... I must say though, I agree the older versions had a LOT of bugs, and I went through alot of shit before finally finding this version that actually works...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Originally Posted by NChatch
CONS:
2) Ehh yah i guess, but nothing really major.
3) You're right, i'm not running a GM map sensor on my car with UD fine. Just cuz your tuner is/was retarded doesnt mean the software doesnt work.
4) How did u come across this? you really are retarded.
5) no it cant, you're right on that 1.
6) I've only seen files get corrupted on chris's car once.
7) Fuel multipliers are NOT off, you are, yet again, retarded. Hell newer versions of ud dont even have fuel multipliers :hammer:
You are right there are alot of versions, but how many were official downloads? and how many were just floating around on the forum? thank you
