what exactly do i need to swap a b16a2 into my 94 hatch?
i got the motor and tranny. now exactly what else would i need to swap it into my 94 hatch? how can i make this obdII motor work in my obdI car? and my buddy told me i could use a 94-97 integra to get the motor mounts. is that true or what will i need thanx. and if anyone knows someone selling what i need then let me know.thanx again tr.
According to HMotorsOnline.com, a complete changeover consists of:
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
FLeuro
TheCommision
FLeuro
TheCommision
if you wanna make that obdII motor work in your car, get a obdI harness, dizzy and ecu.
you CAN use the obdII harness just about 4 plugs or so will not be used and it does plug right in to the obd I ecu.
you are correct on the mounts, use 96 gsr non ABS axles, keep your shift linkage and you should be okay
you can keep the motor obd2 just find a obd2 integra harness. it will plug into the shock tower and your good to go. just run an obd1 ecu. no need to change the dist, injectors, or alt. plugs.
Great accomplishment only comes with great risk. I’ll accept the crippling, gut wrenching disappointment of risking all, and failing, but only by putting my whole heart and soul, my whole being into something, will I have the chance to walk among the stars.
Those who risk nothing, those who live their lives in fear, will never have that chance.
Failure is not a sin. It’s being too afraid to even try, that is a sin.
mycbr900
11-24-2005 03:36 PM
