Which Oil for turbo Honda
addicted to boost
on
Which weight oil should I run im my 2.0L Turbo Civic?
Mobil 1 10w30
or
Mobil 1 15w50
Which one and why???
Thanks..
Mobil 1 10w30
or
Mobil 1 15w50
Thanks..
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by p51f4c70|2 [/1]
d035 17 |234lly m4773|2...175 g01|\|g 70 bl0\^/ up 4|\|y\^/4y5.
h0|\|d45 d0|\|'7 l1k3 7u|2b05.
H0|\|57ly...7h3y d0|\|7 l1k3 5y|\|7h371c 01l [/QU073]
7h15 15 7h3 m057 1g|\|0|24|\|7 p057 1'v3 3v3|2 533|\| 1|\| 7h15 f0|2um. Pl3453 k33p y0u|2 c0mm3|\|75 70 y0u|253lf 1f y0u h4v3 |\|0 U53FUL, 1|\|f0|2m471v3 (4|\|d m0|23 1mp0|274|\|7ly, 1|\|f0|2m3d) 1|\|pu7 70 4dd. 3><4c7ly \^/h47 4|23 y0u b451|\|g y0u|2 0p1|\|10|\| (51|\|c3 175 4b50lu73ly |\|07 f4c7) 0|\| 4|\|y\^/4y?
0h y34h, 7h15 h0|\|d4 pu75 d0\^/|\| cl053 70 400hp 47 7h3 \^/h33l5 4|\|d h45 d0|\|3 50 f0|2 qu173 50m3 71m3. H0\^/ much 15 y0u|2 "P05 D5M" pu771|\|g 0u7 4g41|\|?
|\|0\^/ 70 4|\|5\^/3|2 7h3 qu35710|\|, 1 \^/0uld |2u|\| 7h3 M0b1l 1 15\^/ 50 |\|0\^/ 7h47 y0u|2 m070|2 h45 50m3 m1l35 0|\| 17. 1f y0u |\|071c3 |\|0 ch4|\|g3 1|\| 01l c0|\|5ump710|\|, 7h3|\| 571ck \^/17h 17. \^/3'v3 u53d 7h3 10\^/30 M0b1l 1 4|\|d f0u|\|d 17 70 b3 700 7h1|\|, c4u51|\|g 0cc4510|\|4l 5m0k1|\|g f|20m 7h3 7u|2b0. 1 p3|250|\|4lly d0|\|'7 7h1|\|k y0u |\|33d 5y|\|7h371c bu7 1f 17 m4k35 y0u 5l33p 34513|2 47 |\|1gh7, g0 f0|2 17 m4|\|
Originally posted by Vapor
This is the most ignorant post I've ever seen in this forum. Please keep your comments to yourself if you have no USEFUL, informative (and more importantly, informed) input to add. Exactly what are you basing your opinion (since its absolutely not fact) on anyway?
Oh yeah, this honda puts down close to 400hp at the wheels and has done so for quite some time. How much is your "POS DSM" putting out again?
Now to answer the question, I would run the Mobil 1 15w 50 now that your motor has some miles on it. If you notice no change in oil consumption, then stick with it. We've used the 10w30 Mobil 1 and found it to be too thin, causing occasional smoking from the turbo. I personally don't think you need synthetic but if it makes you sleep easier at night, go for it man
knocked the fuck out!
95 Supra Turbo 6 speed
11 SWP STI sedan
11 SWP STI sedan
im a firm believer in the 15w50 thats all ive run in my car and seems to be doing very well. Mattback can vougue for me im always pickin some up from his work.
The Schnoz Berries Taste Like Schnoz Berries
AIM: TegraRacer97
AIM: TegraRacer97
Just so you know..my pos dsm is putting down 0hp. Currrently it does not run. Which seems to be a common problem for dsms.
when I posted that remark jeff (cronic) was here and was telling me that synthetic oil will mess up your cams/cam. Or which is what the cam munufacturs say. (could not find any written proof on this in 5 min.)
Just a side note that may be worth while.
When is the most wear and tear done on a engine? At a cold start up.
So in theory you would want the thinnest oil possibile at start up to fully circulate on a cold engine. But yet still have a thick consistancy on a warm engine. Which I think 10w 30 will do..
Either oil should be ok.....I'm assuming since you have around 400hp that you do have some sort of aftermarket cam in there..just check it out and see what the manufacture has to says about synthetic oil.
Heavy car with a 2.5L
I would go with 15w30
-450 lb/ft of torque + no traction = alot of fun
-The Lightning is the epitome of the phrase "Hey ya'll watch this!"-Motor Trend
-"Areodynamics are for those who can't build engines"-Enzo Ferrari
