- DINAN install?
- Know anyone who makes Intercooler end tanks?
- Thinking about NOS...Need help for a n00b.
- intercooler and down pipe question
- need downpipe made..WHO?
- greddy type s wastegate?
- BOV adaptor plates
- What are the drawbacks to running Meth/alchohol injection?
- Turbo oil drainage. Why does it have to be gravity drained???
- Possible to rotate turbo assembly???
- Vacuum & BOV
- Turbo and Compression
- rubbing alcohol?
- Anyone need an exhaust housing for a p-trim wheel?
- Opinions?
- World Electronic$ Total Boost Controller
- turbo exhaust manifold
- Downpipe wont fit anymore
- TT turbo a v8
- anyone have something to test for a boost leak???
- Tial BOV For Sale
- Could someone make a sticky or FAQ for turbo technicals?
- n20 hit doesnt "feel" right
- boost vs. vacum stupid ?
- apexi turbo timer
- who does turbo rebuilds?
- Good Sites
- boost gauge splice
- Silly question?
- boost controller problem
- Pipes
- gt28r
- apexi auto timer
- Intercooler Piping
- Silicone coupling
- turbo housing clamp
- do i need it
- V-band Discharge Adaptors
- fuel system uprgades
- which precision turbo???
- n2o rx7
- broken bolt
- << Tampa Racing Presents Track Event # 7 >>
- Turbo Timer ?
- Turbo Time & Boost Controller?
- blowzilla?
- what in the flying hell is the difference???
- Turbo Vs Supercharger
- does this kit sound good to you?
- final verdict...
- FMIC question
- nitrous conversion
- BOV Wanted
- DIY Wide Band O2
- synthetic vs. non synthetic
- cheap charge pipe fabricator?
- need t04 oil return flanges.
- Profec B Instructions
- tech: e-cutout
- Turbo exhaust manifold question
- Turbonique
- Methanol
- Nitrous ???'s
- Carb -vs- EFI + Turbo Debate
- took off my FMU
- seen this before?
- Oil catch can question?
- N2o
- Intake piping and its importance.
- Type S BOV flange and welding
- Do me a small Favor
- K-series turbos?
- changing wastegate springs???
- DNA boost controller
- How much should a 75 shot change the ET>>>
- what to get
- quick question!
- newbie
- Fluttering BOV
- Fuel pump issues...
- Watercooled Turbos: Pros and Cons
- 270 pr 360 and 4 bolt or 5 bolt
- Mounting the Nitrous bottle Question?
- Vtec head question
- Difference between
- BOV boost limit?
- Need A Tial Wastegate Spring A.s.a.p.
- boost psi.
- HKS 40mm Standard wastegate question.
- turbo install
- Manifold Gasket
- BOV questions
- stupid nitrous questions...?
- Turbo Timer
- warm or cold air???
- Blow off valve flange
- Iridium IX plugs
- Welding?!
- Turbo Feed Oil Line
- anyone using M&H slicks
- Greddy 31v or pwr intercooler?...
- Lets talk intercoolers
- Fuel Line Q's
- Full Race Exhaust Manifold
- Garret T-70 for $450....
- HELP!!!Broke off a bolt in my manifold....
- Tial 38mm wg fit on 35mm ?
- surging
- VBand
- Synthetic Oil with Rebuilt Turbo
- Bad Turbo
- Engine Sleeving
- cams
- a new 2.0 93 octane record!
- Sfp
- N2O on my Integra....
- Pistons?
- Anyone wanna trade BOV's????(greddy)
- My new turbo kit!
- Swain Tech BBE Coated Intercooler
- SAFC boost and fuel question
- another MC question
- Cheap Intake Piping
- Where is Amazon Hose at??
- MBC question
- Thanks Vapor (Full Race and TiAL)
- Anyone got a 2 or 3 bar GM MAP I can borrow?
- Rear mounted turbo
- What kind of pipe?
- Turbo Rebuild
- Any wone know how much boost you can push in a 1.8t motr
- tubular exhaust manifold
- Another turbo question!
- kenne bell twin screw
- ZEXs full throttle module
- Zex or Shot???
- blitz SBC ID info
- NOS Pill Question
- who rewelds endtanks?
- FPR & return line install
- Turbo charger: how much is too much
- accord turbo question
- Need Your Thoughts/Insights
- Worst Electric Supercharger Scam Artist Evar
- Help me find a turbo!!
- SKUNK2 Turbo Camshafts
- Help Me Find A F*cking Intercooler !
- NX Inter-cooler
- NX jets
- Twin Turbo on crx ???
- i need some numbers...
- which dsm turbo should i go with my d16y8
- Bottom End Question
- Hesitation problem HELP!!
- 2.5 inch hosing
- is anyone using a blitz SBC-ID??
- Studying Profec B
- Opps!
- boost calculations
- greddy aluminum flange
- Total Seal rings?
- Good Places To Look For Air - Air Intercoolers
- Tial Flanges
- My dyno #'s from Saturday
- Best FPR?
- Air-to-Air vs. Liquid-to-Air Intercoolers
- Dyno results for the Mustang
- IC Piping
- Which pill to to reduce oil pressure in turbo
- Anybody sell Tial products?
- Has anyone used the new Nozzle nos system?
- Exhaust Ticket Help Really Needed
- Lean issues....
- Queston on 1.8t
- Bov position theory
- When ingenuity goes bad......
- Precison SC61 Turbo?
- Unsettled N2O debate II *confusing*
- supercharged?
- Zex Accessories
- Wideband o2's
- Auto Tuner...?
- New Parts
- nitrous bottle
- Holset turbo on small displacement motors
- Turbo Question
- t3/t4 60-1
- pressure drop question
- New Tune - I'm stuck under 400hp and I can't get up!
- Identify this Wastegate??
- "The unsettled debate nitrous "
- Identify this wastegate?
- Turbo or Supercharger?
- Blitz SBC-iD Instructions (Attn: FordMan)
- Can my engine take this?
- Piston Coatings
- Turbo suggestions for a friend (mr2)
- What exactly does HKS do to Garrett turbos?
- race gas VS pump gas??? tech
- Whats the most you ever....
- Wastegate Problems
- Turbo 2.3 Ford with a big turbo
- *deleted*
- Whats this intercooler?
- New turbo install, where does this go?
- How much Hp can I pull with this!
- This Ic any good?
- V-Band Clamp???
- Local Block Builders Vs Others
- question
- Need shop for custom downpipe
- Intercooler piping wrap, do you use it, did you get a large gain like I did?
- Got My Blitz SBCID Boost Controller Today
- Noob to FI =\ questions
- Turbo Problems
- Hahahaha Ooops
- Did some datalogging today
- Tial 35mm vs 38mm springs
- Double standard on nitrous?
- Question for T3/T4 masters
- mandrel bent turbo piping
- To much of a bend??
- need help tuning car
- boost VS tubro size, VS power
- Thermal Wrap?
- I'm definitely keeping the car now!
- New turbo
- I finally bought my Profec B Spec II
- turbo question
- identifying turbo exhaust side flange...
- No boost till 5k
- Turbo Question
- Precision SC61 (TA31) to Precision SC63 (T350 big shaft small house) Comparison
- Nitrous Oxide N20
- Modified actuator to lower boost
- HEY vapor hit me up I wanna talk to ya !!
- Where to get custom test pipe made?
- Pardon my ignorance but, do diesels have to have turbo?
- Oil in compressor outlet
- What EGT Gauge Do You Use ?
- sizes
- launching a turbo car
- Exhaust cutout and downpipe ??
- Effects of turbo not hooked up
- ls, b20, or b16 turbo???
- racing from a roll with boost
- powershifting
- Vertical vs Horizontal Flow
- Plug reading? A lost art?
- Would you recommend?
