American Iron Tech A haven for those who love classic American muscle cars
How to diagnose that errant noise
Old Jan 23, 2025 | 07:44 AM
Default How to diagnose that errant noise
By David S. Wallens
Jan 18, 2025 | Diagnosis, Restoration, Project car
Tapping or ticking from the top end of the engine
→ Loose valves or other valvetrain issues
Tapping or ticking from the bottom end of engine
→ Main or rod bearing issues
Rushing air sound that increases with engine speed
→ A loose component in the intake tract
Screeching that changes with engine speed
→ Worn or loose drive belts
Pinging under acceleration
→ Ignition timing off and/or not enough high-octane fuel
Engin roaring sound (in a bad way)
→ Exhaust leak
Screaming from the front of engine
→ Worn coolant pump
Ticking from the rear of car
→ Electric fuel pump issues
Bad bearing/rattling sound that goes away when the transmission is in neutral and the clutch pedal is depressed
→ Worn input shaft bearing
Whirring that changes with car speed as well as side-to-side suspension loading
→ Bad wheel bearing
→ Tire issue
Squeaking or groaning over bumps
→ Dry or worn anti-roll bar bushings or suspension bushings
Clanking from underneath over bumps
→ Loose suspension components or worn suspensions bushings
Clanking, hollow sound from underneath over bumps
→ Loose exhaust system
Scraping or ticking sound that changes with car speed
→ Worn brake pads
Screaming from the passenger seat
→ Driving too fast or erratically
Jul 19, 2016 09:06 AM
slizzle
Feb 18, 2008 08:58 AM
Jordan Y.
Mar 26, 2004 04:48 PM
accord95
Dec 8, 2003 10:19 AM
specie
Feb 25, 2002 09:04 AM
