How To: Testing fuel injectore
https://www.youtube.com/watch?v=yFv5IWdANGs
How To Tell If a Fuel Injector Is Bad Needs Replacing .How To Test Fuel Injectors ..How To Check Fuel Injectors . Obd1 Obd2 all cars: Toyota Honda Civic Lexus corolla lexus bmw chevrolet pontiac volvo impala corvette camaro mustang .. ford landcruiser Misfire Code P0304 . How To Ohm Test Fuel Injectors . Noid Light . Clogged Fuel Injectors . Short . Use a Multimeter to check |
By Chrisfix
https://www.youtube.com/watch?v=tA_E6X4ISgQ How to test fuel injectors for pulsing, Using a screwdriver to test fuel injectors, How to check fuel injectors, fuel injector cleaning, how to clean fuel injectors, This video will show you how to test your fuel injectors to make sure they are firing. You place a long screwdriver to the base of each injector and put your ear to the end of the screwdriver (like a doctors stethoscope). You should hear constant clicking. If not, then your injector isn't firing or is firing intermittently. Symptoms of bad injectors are a check engine light with codes P0300 through P0308, misfiring, hesitation, poor fuel economy, stalling, and a poor idle. Using a Multimeter to Check Fuel Injector Resistance https://www.youtube.com/watch?v=ZVXch... ***If the video was helpful, please give it a "thumbs up" and consider subscribing. Leave any questions or comments below and I will answer them as well.** Follow me on Facebook: https://www.facebook.com/chrisfix8 Follow me on Twitter: https://twitter.com/ChrisFixed Subscribe: http://www.youtube.com/subscription_c... Disclaimer: Due to factors beyond the control of ChrisFix, it cannot guarantee against unauthorized modifications of this information, or improper use of this information. ChrisFix assumes no liability for property damage or injury incurred as a result of any of the information contained in this video. ChrisFix recommends safe practices when working with power tools, automotive lifts, lifting tools, jack stands, electrical equipment, blunt instruments, chemicals, lubricants, or any other tools or equipment seen or implied in this video. Due to factors beyond the control of ChrisFix, no information contained in this video shall create any express or implied warranty or guarantee of any particular result. Any injury, damage or loss that may result from improper use of these tools, equipment, or the information contained in this video is the sole responsibility of the user and not ChrisFix. |
try this again
