American Iron Tech A haven for those who love classic American muscle cars
bbc 468 project pic's inside almost done
Old Aug 12, 2007 | 03:48 PM
slowmoving1's Avatar
Default bbc 468 project pic's inside almost done
well heads installed 990 castings fully ported 2.30 int 1.88 ex
arp studs
1071 felpro mls for heavy nitrous use
forged rotating assembly about 12-5 comperssion
herbert solid flat tapet cam 266duration @.50 int 276@.50 ex around 620 lift crane roller rockers comp push rods
wating on victor jr intake old torquer 2 for pic
850cfm carb proform race series
summit dizzy mechincal advance will be locked out
looking for 600-650 hp on motor plus 400 on gas
Old Aug 12, 2007 | 08:35 PM
myltwon's Avatar
Bolt-On 2v GT
fuckin sexy bro, I love BBC's
Old Aug 12, 2007 | 09:03 PM
Suicidal Racing's Avatar
Has V.I.P in HELL!
your carb is to small i think..why didn't u go with a roller cam do?
also i will recomend stud gurdles.
whats the max rpm u going to run..also how fair down is your ring stack..it should be around atleast 250 down..if not u will tourch a ring with that size shot.
Old Aug 13, 2007 | 06:05 AM
on top of 1st ring was over .350. this is a heavy piston made for lots of gas,max rpm will be 6500-6800. roller cam was more money and i've had great luck with solid flat tapet cams the break in and right springs are the key factor. also my ring gap is 35 top 29 bottom so it should no burn up top ring. and the 400 will be total in 2 stages 250 off the line 100-150 about 3 seconds out.
i will get new carb in future the 850 is all i afford for now.
thanks for comments, keep them coming
Old Aug 13, 2007 | 06:07 AM
thanks
Old Aug 13, 2007 | 11:57 AM
GradeA_TireFryer's Avatar
All American, rice eater!
i have that same intake on my bbc (it has been polished to a mirror) - ever use one before? - what heads are you using - i have a pair of ls6 heads that have been worked (port, gasket matched and o-ringed, big-big valves and 3 spring setup on roller rockers.
Old Aug 13, 2007 | 12:00 PM
Has V.I.P in HELL!
i know some one with a pro system 1000cfm carb for sale..ran only a couple times he wants 600$ i think for it.
it was run on a all motor 347 combo up north.
Old Aug 15, 2007 | 02:48 PM
never used one before not room to port to 1275 gasket.
these are 990 castings fully worked
Old Aug 15, 2007 | 02:51 PM
any more info on carb or tell him to call me spencer 352-603-1062
4150 style or 4500 do not know much pro system
Old Aug 15, 2007 | 09:53 PM
Has V.I.P in HELL!
4150 i believe..i was just talking to him..i will shoot him a pm saying to call u..he lives up north.
