1968 Pontiac 350 motor with transmission attached. $550(2 sets *price drop*)
two different 68 firebirds. I am going a different route and no longer need these motors or transmissions. Both were running(needing carb rebuild 2bbl). One of the motors needs a harmonic balancer. If I can find the one I bought I will give it to you.
Shoot me a PM if interested. |
so... what exactly are you selling? 2 motors or 2 firebirds?
Originally Posted by badhombre
(Post 8792656)
Both cars were running and driving(needing carb work and one needs a harmonic balancer) Both motors were pulled about a year or two ago and have been sitting in the garage. I am going a different route for the engine and will not be using these motors.
The transmissions are TH350 automatics. These are ORIGINAL 1968 motor and trans combos. I will not be using them. Good for a motor to rebuild or if you are looking to build a year correct firebird. $550 will get you one 1968 Pontiac 350 motor with a transmission. If you want both motors and transmissions at once I will cut you a deal. Just wanted to clear up the ad as I had some questions. email for a quicker response guado 1 @ gmail dot com remove spaces. |
