+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Gangsta What 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride has a reputation beyond repute 95Ride's Avatar
    Join Date
    Oct 2002
    Location
    Land O' Lakes, Fl
    Posts
    736
    Feedback Score
    20v 1.8t mk2 swap speedo/tach question
    im in the process of doing a 1.8t 20 valve swap into a mk2 gti. im going to use mega squirt. i plan on using the mk2 tranny (for now). i want to retain the mk2 cluster so i was curious whaat way to go about adapting the speedo/tach from the mk2 with the 1.8t motor.
    i havent started the actual swap yet as im waiting for my buddy to pull what all he wants off the loaner car. Just doing all my research and gathering parts as im not really familier with 1.8t.
  2. #2
    Resident VW enthusiast 84Roc is an unknown quantity at this point 84Roc's Avatar
    Join Date
    Mar 2002
    Location
    Lutz, Flordia, USA
    Posts
    102
    Feedback Score
    Fourtitude.com - mk2 cluster with 1.8t swap questions
    looks like a corrado g60 one may work.
    might be easier to swap in a 1.8t drive by cable found in an earlier 97-99 passat/a4 instead of the later drive by wire ones
    -Andrew Wong
    1984 VW Scirocco
    1987 VW Quantum
    [img:a3bf91d95a]http://www.tampaveedubs.com/forum/uploads/Sigimage1.jpg[/img:a3bf91d95a]
  3. #3
    Registered User 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v has a reputation beyond repute 8716v's Avatar
    Join Date
    Jan 2004
    Location
    Pinellas
    Posts
    375
    Feedback Score
    if your keeping the tranny from your car and cluster from you car then your speedo will work just fine as its mechanical
    . then just need to find a signal from megasquirt to send to your tach.
    Quote Originally Posted by Biodizzle View Post
    if there are no internal engine mods, it is stock. i.e. cam, heads, pistons.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
