+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
  1. #1
    Registered User neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute neondriver has a reputation beyond repute
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    need 4x4 help please....
    i bought my 99 f250 not too long ago and it pretty much makes it through except the 4x4 doesnt work and every time i get stuck i start to look and check it out and end up giving up but now i got stuck again in a stupid spot for an hour which wouldnt have happend if it just worked anyway heres my problem.....
    no 4x4
    *with the truck running in park the front drive shaft spins by hand freely
    *i turn on the 4x4 switch (i have no locking hubs) the way the owners manual says and put it into park
    *with e the 4x4 switch on the axel now doesnt spin, so the 4x4 switch is telling the motor to engage the driveshaft and the drive shaft is locking in 4x4 but i have no 4x4
    my guess is that when it spun freely in park with the 4x4 off the transfer cash didnt lock it obviously (which it shouldnt) but when i spun the front drive shaft by hand in park the front tires should have tried to spin right?
    so to me it seems i have a problem in my front axel, maybe a stripped gear? but i think a stripped gear would make nasty sounds while trying to drive?? or is there a way the front axel locks in besides at the transfer case? i just need other possable ideas because so far i dont have a solution
    why did i drive a neon? click the link to the old ride: http://acrracing.tripod.com/
  2. #2
    Porno Music Producer zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz's Avatar
    Join Date
    Jan 2006
    Posts
    8,768
    Feedback Score
    14 (100%)
    Does the light come on the dash? it could be the 4x4 switch itself or the module behind the glove box. Not sure tho if your transfer case is locking in then it will be your hubs. you can get new ones with manual locking hubs and that will fix it if its just the hubs not locking. If you want to keep automatic locking hubs there are vacuum lines that run to them that lock them in which are probably messed up in someway.
  3. #3
    Fir Na Tine CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR has a reputation beyond repute CRXSiR's Avatar
    Join Date
    Apr 2002
    Location
    St.Pete
    Posts
    3,167
    Feedback Score
    1 (100%)
    if its an automatic..you have to put it in reverse to put it in 4wd..
    00 Ranger
    2.5l 5spd
    DJM 2/3 drop
    Roush sway bars
    CAI
    04 Crossfire Limited
    V6 5spd auto
    Dual intakes
    Eibach 1.5 drop
    Rear Adjustable Control Arms
    09 Nightster
    V&H short shots
    Screamin Eagle intake
    Tuner
    more..
  4. #4
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    Quote Originally Posted by zhillz View Post
    yeah the light came on, and low light comes on when i put it in low gear. im thinking its the vac lines. i had an old jeep that had a vac line problem.... the front driveshaft locks in so its something in the front axel but i dont have locking hubs its on the fly only, my friend has a 250 superduty and its on the fly but he has locking hubs...i finally bought a chiltons repair book and there is a actuator vac fed motor on the front axel so im going to look there tomorrow and see if its all woking
  5. #5
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    Quote Originally Posted by CRXSiR View Post
    yep its an auto. another weird thing when i switch it to 4x4 and put it into reverse and then drive the truck revs high and doesnt really shift acting as if its in 4 low and then when i stop turn the 4x4 off and go again it drives normal, so im guessing everything is working like its susposed to but everything points to something on the front axel...but at least i know something else to look at tomorrow when i start messing with it again.
  6. #6
    Join Date
    Apr 2002
    Location
    St.Pete
    Posts
    3,167
    Feedback Score
    1 (100%)
    ya..for some reason you have to put it in reverse..(not moving)..put your switch to 4x4 high/low..whichever you prefer..then put her back in drive..then take off..it will seem like its reving high cause of gearing..it does seem like you have something going on, but it still should at least shift into 4x4..also the front end i had problems with it locking..i just locked the hubs instead of leaving it on automatic..then it will always lock..and sure enough it does now..
    00 Ranger
    2.5l 5spd
    DJM 2/3 drop
    Roush sway bars
    CAI
    V6 5spd auto
    Dual intakes
    Eibach 1.5 drop
    09 Nightster
    V&H short shots
    Tuner
    more..
  7. #7
    is breaking shit IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose has a reputation beyond repute IwinUlose's Avatar
    Join Date
    Oct 2006
    Location
    lutz
    Posts
    1,617
    Feedback Score
    1 (100%)
    No you do not need to put it in reverse. There are no locking or unlocking hubs. You need to check the vacuum lines from the solenoids on the firewall all the way down to the acuator mounted on the differential. If you have any vacuum leaks 4wd will not engage. With the right front axle not locked 4x4 will not work.. The vacuum line leading down to the acuator are blue and red...
    Quote Originally Posted by killerMikeD View Post
    What kinda pussy needs sprockets to do a wheelie anyways?
    Quote Originally Posted by 95coBraSVT View Post
    I think I still take the "stupid owner" of the month award here.
    RIP Tad.
  8. #8
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    Quote Originally Posted by IwinUlose View Post
    i messed around today and took off the cover for the front driveshaft and the actuator, i have a blue and red vac line that goes to 2 sylonoids on the firewall on the passenger side. the actuator on the axel doesnt move when someone in the cab switches it in to 4h/L. the vac lines seem fine, im going to check if the sylonoids have power and if theres a vac leak.... i found the vent tube from the axel just ended near the sylonoids which was kinda weird, and one of the vac lines was broken at what looked like a check valve or filter but i fixed that and still nothing....hopefully its something stupidly dumb thats wrond and once i figure it out it will work and not cost an arm/leg.
  9. #9
    Join Date
    Oct 2006
    Location
    lutz
    Posts
    1,617
    Feedback Score
    1 (100%)
    If you dont have a vacuum leak you possibly might have bad solenoids. Check them with a 9v battery and see if they click.. Its very likely you have a bad acuator. Remove the acuator and see if you can move the shift fork. The shift forkes are known to brake....
    RIP Tad.
  10. #10
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    so i had a broken vac line i fixed it and the lever on the front axel now moves back and forth when i turn 4x4 on/off but nothing engages so now its down to something ni the front axel???
  11. #11
    Join Date
    Oct 2006
    Location
    lutz
    Posts
    1,617
    Feedback Score
    1 (100%)
    do have a floor shifter or switch on the fly?
    RIP Tad.
  12. #12
    Join Date
    Nov 2003
    Location
    Holiday
    Posts
    2,611
    Feedback Score
    6 (100%)
    shift on the fly
  13. #13
    Registered User sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer has a reputation beyond repute sl2racer's Avatar
    Join Date
    May 2004
    Location
    port richey, florida
    Posts
    3,104
    Feedback Score
    4 (100%)
    is it possible that with a bad vacuum line that it was semi engaging the hub in the beginning of the problem but now has worn down the teeth on the hubs from tring to get it to engage with the vacuum broken repeatedly.
  14. #14
    Join Date
    Apr 2002
    Location
    St.Pete
    Posts
    3,167
    Feedback Score
    1 (100%)
    i read the manual on mine..best way to engage and disengage is to put it in neutral..just some cheap way to try it..but hopefully you wont need all new internals on your axle, but thats what its kinda sounding like..OR something maybe going on with your transfer case..
    00 Ranger
    2.5l 5spd
    DJM 2/3 drop
    Roush sway bars
    CAI
    V6 5spd auto
    Dual intakes
    Eibach 1.5 drop
    09 Nightster
    V&H short shots
    Tuner
    more..
  15. #15
    Registered User prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute prymerintegra has a reputation beyond repute
    Join Date
    Jan 2005
    Location
    lakeland
    Posts
    407
    Feedback Score
    pull your front diff cover and see if spider gears or ring/pinion gear is ate up or chipped .. had the same prob in a buddys f150.. put a new carier in it and everything works fine !
    MiKe..
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
