+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    layin frame for life 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7 has a reputation beyond repute 1stGen7's Avatar
    Join Date
    Jul 2004
    Location
    lakeland
    Posts
    2,258
    Feedback Score
    2 (100%)
    pinion angle help
    i read a thing online that says take 4 mesuments.. i got all 4 mesuments.. the tranny is down 5* the front driveshaft is down 2.5* the rear driveshaft is up 5* and the rear end is up 5*.. maybe you can figure out what shims i would need cause i have no clue what to do from here.. i read what people where saying like 10 times and still got confused by it
    sub stage. 4 Cerwin-Vega V-Max152
    sub amp. Power Acoustik BAMF-5500
    mid's. 6 powerbass 4XL 6.5's and 4 DB drive 8's
    mid's amp. Power Acoustik BAMF-1200
  2. #2
    Porno Music Producer zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz has a reputation beyond repute zhillz's Avatar
    Join Date
    Jan 2006
    Posts
    8,839
    Feedback Score
    14 (100%)
    Your tranny and diff need to be around 3* from each other.
    basically, the angle of the output needs to be parallel with the angle of the pinion under load. with leaf suspensions, generally the rule of thumb is to set the static angle for the pinion about 3* down from parallel with the output shaft, because it tips up under load. under load, you want it too look like this:
  3. #3
    Join Date
    Jul 2004
    Location
    lakeland
    Posts
    2,258
    Feedback Score
    2 (100%)
    hmm so should i get 4* shims? i dono my trucks lowerd
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
