+ Reply to Thread
Results 1 to 11 of 11
Thread: Lifting 2000 Chevy Silverado 2wd
06-22-2008 01:38 PM #1
Im trying to lift my ext cab short bed 2000 chevy silverado 9" front 6" rear. I am going to get 3-3 out of that with a body lift so basically 6" front 3" rear suspension.
I have a 3-3 suspension kit now. 3" lift springs 3" blocks. I got it today its in the box I dont want to put it on till I know how and what I am doing.
If I put these springs on the front I was told stock shocks will work for a little bit on 3" but its better to get new ones asap is that true? If so is it possible to use stock shocks for temp on 6" lift too?
Also how can I get the other 3" of lift suspension wise in the front? I was thinking spring spacers, but will that work. If I got 6" lift shocks could I do 3" springs and 3" spring spacers, and that be all I need to do, or is there other things that come in play like camber or any relocating or anything?
Also if any1 has a body lift kit or spacers let me know.
Joey E-THUGGIN It Up On TR. Rep For his Keyboard Ninja Skillz Yo.
06-24-2008 05:04 PM #2Registered User
- Join Date
- Jun 2007
- Posts
- 21
- Feedback Score
- 1 (100%)
dude your stock shocks should work for the 3 inches but will need to be replaced and you wont be able to use them for the 6 inch and for the other 3 inches the only thing i can find is a 2 inch spacer for a leveling kit but fabtech makes a 3 inch spindle kit or you can buy the complete kit that is 7 in the front and 6 in the back
06-24-2008 10:55 PM #3
Actually the stock stocks wont work on a 3" system. The shocks act as the travel limiter in the front suspension as there are no bumb stops on a 2wd GM. What size tire are you looking to clear? IF you look under the thread created by ar_audio we installed an setup the lift for his 06 Crew cab silverado. Stock tire size was the equivalent of a 28" tall tire. We ended up with a little 5" of lift in the front an a 3" block in the rear. IT all depends on what tire you plan on trying to run. The backspacing of the wheel plays a major roll on what tire you can clear with no trimming. If have any questions or would like me to setup a reasonably priced setup just let me know. info is in the sig.
On ar-audio's crew cab we had to do some clearencng beccause the use of a 18x10" wheel, an a 33x12.50 Toyo M/T.
06-24-2008 11:14 PM #4Registered User
- Join Date
- Nov 2005
- Location
- Altitude Adjustments Off Road
- Posts
- 3
- Feedback Score
- 0
Stock shocks will not work on a 3" lift. They barely fit on a leveling kit. Like above use the Fabtech Spindles I do them all the time....
Rick Merrill
Altitude Adjustments Off Road & Performance
Hudson, Florida 727-819-0060
07-05-2008 09:11 PM #5
i ended up doing 4" spindles and 2" coil spacers and 2" blocks and 3" body lift making 9"-7". I was told the spindles dont effect the shocks at all. And the spacer is only 1" tall even though it lifts 2" so its like only a 1" increase to the shocks in the front thats what I was told. Now as far as the back I got lift shocks that are like 3" or something. ill post up pics when i get it installed
07-06-2008 11:34 PM #6
why lift a 2wd? bagit!
A clever person solves problems but a Wise person avoids them... A.Einstein
07-07-2008 06:17 PM #7
look at my sig. Ive already built a show truck. im lifting it because I want to lift it.
07-07-2008 11:22 PM #8
07-08-2008 01:09 PM #9
07-08-2008 08:03 PM #10
I just said because I want to fucking lift it. I didnt say oh im going to lift it and go hit some mud. Im fucking lifting it because I want to fucking lift it because I want to lift my fucking badass desiel 1500 because i dont want a 4x4 and i like the lifts better. I dont want a bagged truck. I already built a top of the line truck in that scene/
07-08-2008 10:37 PM #11
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
