HELP: Oil Leak on Rear of Motor (Ford 6.0L PSD)
Old 04-12-2008, 06:54 PM
gone fishin
Cecil's Avatar
Default HELP: Oil Leak on Rear of Motor (Ford 6.0L PSD)
After returning from a 600 mile trip where I was towing about 6,000lbs (including the trailer) I noticed an oil leak.
The vehicle is a 2003 6.0L PSD 4X4.
The oil appears to be coming from the rear of the motor, high enough to leak down both sides of the transmission.
However, it appears to be concentrated more heavily on the drivers side.
My initial thought was the "Rear Main Seal", but I am not really sure.
The oil level seems to be within tolerance (not much has been lost).
The oil is NOT milky (does not appear to have water in it).
There has been no noticeable change in performance (never missed a beat coming home towing a 6,000lb trailer 600 miles).
There has been no decrease / increase in oil temp.
It appears to drip only when the vehicle is running (it will leave a couple of small puddles of oil when parked or left running idle).
Attached are a few pics that may provide some insight as to what I am talking about.
My apologies for the poor quality, they were taken at night with me laying underneath the truck.
Any input will be appreciated.
Thanks,
Cecil
Old 04-12-2008, 11:07 PM
Fir Na Tine
CRXSiR's Avatar
more than likely its the rear main seal!! i would be making those people that rebuilt that tranny for you, do it for FREE!!
00 f250 ecsb
7.3 pstroke(92k miles)
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
Old 04-13-2008, 05:28 AM
milesengineer's Avatar
Could possibly be the turbo pedestal. The 7.3 had them and not sure if the 6 liter does or not. But there are orings on the pedestal that will break and makes it leak.
Old 04-13-2008, 07:52 AM
gone fishin
Cecil's Avatar
Thanks guys!
I found this to be very helpful as well:
The most common leaks on the 6.0 are as follows in descending order of occurance: (Notice the First four items comprise 65% of all reported leaks and are a simple fix.)
CAC Tubes = 21%
ICP Sensor = 16%
Glow Plug Harness = 14%
Cam/Crank Position Sensor =14%
Front Crankshaft Seal = 8%
Upper to lower block seal (skirt) = 5%
HPOP cover = 4%
Oil Cooler (this leaks into engine coolant) = 4%
Front or Rear Engine Cover = 3%
Rear Crank Seal = 3%
Turbo Charger & VGT actuator = 2%
Covers (oil pan, valve covers, breather) = 2%
Cracked or Porous Block or Head = 1%
IPR valve/Engine Lube oil pump = <1%
Old 04-14-2008, 10:58 AM
Porno Music Producer
zhillz's Avatar
lucas stop leak
$9.99
Old 04-14-2008, 03:17 PM
Protected Taurus .45/.410
88RedRex's Avatar
^^^ over time it will still leak
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old 04-15-2008, 07:18 PM
is breaking shit
IwinUlose's Avatar
Its not a pressurized leak. More thn likely its the CAC tubes. Had a buddy come over last night who also had a oil leak. it was the CAC tubes on his 04 6.0 PSD.
Originally Posted by killerMikeD
What kinda pussy needs sprockets to do a wheelie anyways?
Originally Posted by 95coBraSVT
I think I still take the "stupid owner" of the month award here.
RIP Tad.
Old 04-16-2008, 10:37 AM
gone fishin
Cecil's Avatar
This is a 2003 6.0L Injection Control Pressure Sensor (ICP) that has failed to withstand the pressure of it's job. This caused a dripping oil leak down the back of the engine and it incredibly continued to provide an unbiased signal to the PCM despite the physical damage.
Old 04-16-2008, 10:43 AM
gone fishin
Cecil's Avatar
6.0 PowerStroke bulletins
http://www.forddoctorsdts.com/photographs/index3.php
Oil Leak from Rear of Engine Area:
< Oil leaks from the rear of the engine should be indentified and pinpointed using flourescent dye and an UV lamp. Leaks from the top of the engine can run down the back of the engine appearing as rear main seal leaks (check for upper engine leaks first; Braodcast Message 499. Oil from failed cam or crank sensor o-rings can run along the seam between the main block and bedplate (lower cranckase) joint, apperaing as rear main seal, bedplate, rear engine cover, or upper or lower pan gasket leaks. Cam and crank senaor o-rings are available separately from the sensors (see msg 1268 below). Oil leaks can be cause by removing the front or rear engine covers without first cutting the gasket at the cover/block/bedplate joint, or failure to seal this joint with silicone on assembly. Broadcast Message 5164.
2003-2004 Oil Leak from Head Gasket:
Some engine may exhibit what appears to be an oil leak from the head gasket. Since there is no pressurised oil at the head gasket, a leak at this location is unlikely. Inspect the following area instead: turbo oil feed and return, oil cooler, HP oil pump cover, ICP sensor, IPR valve, valve cover gasket, rocket carrier gasket, Injector and glow plug ports and crankcase breather port. Use florescent dye and an UV lamp to pinpoint the source of the leak. If the leak is from the head gasket, the head should be removed and it and the block checked for flatness. Broadcast Message 0873.
Old 04-16-2008, 06:03 PM
TR Balla Donor Supreme
97BLACKciVIC's Avatar
very informational
