#1 (permalink) |
Car: 95 GST 16g
Tampa FL
: 138565429 |
Need repair welding on 99 Sentra SE SR asap.
Hello,
My clutch pedal mount has broke. The bracket at the top of the clutch pedal, where it bolts to the metal underside of the dash broke. So you press the pedal and it does not actually depress, it just pushes the whole assembly. I went to the dealer today, and theres no actual part, the bracket needs to be repaired with welding. Anyone know a shop or anyone on here that can do it, and how much?? I need it asap! Thanks : ) Dan AIM - M374llic4 |
#3 (permalink) |
Car: 95 GST 16g
Tampa FL
: 138565429 |
Thats part of the problem : \
The bracket is welded under the dash, I wish it were as easy as bringing it in to a shop, someone has to actually lay down under the dash, and weld it up to the metal under the dash, it does not bolt. |
#4 (permalink) |
Car: 95 GST 16g
Tampa FL
: 138565429 |
Can anyone handle this, or know a shop willing to do it? It is in car, in a tight space, but I would not believe to terrably difficult?
Let me know asap! Need it fixed! AIM - M374llic4 813-210-3524 (dont get good signal here though) |
#5 (permalink) |
Car: 2001 Mustang GT
Clearwater
: 373475867 |
Largo Genium Performance Call dave at 727-234-7250
| Sponsored Links |
