+ Reply to Thread
Results 1 to 11 of 11
  1. #1
    Toyotas For Life 82RollaSR5 is an unknown quantity at this point
    Join Date
    Mar 2005
    Location
    TnC
    Posts
    214
    Feedback Score
    Cant believe i forgot to post this on TR 82 Corolla 1JZ Swap
    Well as a select few of you may know i am undertaking a massive project with my first car my 82 Corolla SR-5 Hardtop. After contemplating every Toyota engine(and even nissan engines) i decided hey what about a 1JZ, I can get one with a 5Speed much cheaper than a 2J. My car weighs 2000lbs so why do i need 500HP and with the AC,ps, and hydro fan removed and a nice exhaust i can achieve over 300HP at the crank with open loop warmups and a nice smooth Toyota idle. So $1975.00 later my 1JZ arrived at my Toyota dealership of employment. After 800 dollars in genuine Toyota parts(an an isuzu trooper timing belt) i have the engine externally ready for drop in. And thanks to my dealerships failed drag racing dreams i had an 83 Corolla Shell a free rack and pinion swap at my disposal, So after some mocking ive learned a nice bit of info about a 1JZ and a 4th Generation corolla.
    1. The 1JZ engine mounts and the Stock corolla crossmember sit in the exact same place meaning i can make a simple bracket and bolt it up.
    2.The R154 Shifter sticks right out of the FACTORY shifter hole
    3. a 1JZ looks very nice in a Corolla
    4.The transmission tunnel in a corolla is much to small for an R154. (im looking for an MA70 trans tunnel if anyone has one to cut out)
    5.A 1JZ can use the stock radiator as a Corolla
    6.Cam seals from a V6 Highlander fit a 1JZ
    7.And you are cooler if you own a 1JZ
    The project is currently moving slowly since bills arent cheap and i make only ok money.
    Here be the pics
    In the car
    Mocking it into the 83
    Mounts
    When it was shipped
    And remember always use
  2. #2
    was "dbhmr2" had a mr2 t cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute cornhusker has a reputation beyond repute
    Join Date
    Sep 2005
    Location
    seffner
    Posts
    942
    Feedback Score
    3 (100%)
    nice!!!
    IMPORTANT DEFINITIONS
    CORNHUSKER- domestic car with shopping cart wing
    RICER- Japanese car with fart can
    DereK - Dizzle - D-reK - Big D - DH
  3. #3
    El Tee Juan x2.... IDIOT! SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper has a reputation beyond repute SilverSleeper's Avatar
    Join Date
    Mar 2004
    Location
    Clearwater/Tampa
    Posts
    371
    Feedback Score
    there's more room than i thought between the strut towers. how are you gonna do the radiator and fan setup since the motor sticks through the supports? i wish i still had my old '81 because i always wanted to do something crazy like that. good job!
  4. #4
    RIP Kevin RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra has a reputation beyond repute RTA Supra's Avatar
    Join Date
    May 2003
    Location
    Land O Lakes
    Posts
    1,166
    Feedback Score
    1 (100%)
    Very nice sir!
    Looking for OEM Acura parts? PM me
    GO BOLTS!
    09 Civic Si
  5. #5
    Why so Miata? Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian's Avatar
    Join Date
    May 2004
    Location
    Venice, FL
    Posts
    8,688
    Feedback Score
    Wow dude thats fucking hot!
    ASE: Brakes
    I can get you Pampered Chef stuff. Just sayin'
    RIP JZDeLorean and Tyler
  6. #6
    Join Date
    Mar 2005
    Location
    TnC
    Posts
    214
    Feedback Score
    To answer your question. Once i get the MA70 tunnel(or worst case scenario make my own) the engine will sit farther back in the engine bay making the use of the factory radiator and fan setup possible. The TE72 Tunnel is small. The T50 trans is tiny next to an R154 and the T50 is a tight fit. Once thats out of the way just 2 brackets and make a new sway bar(since the only way to mount a 1JZ in a corolla is using a front sump pan the pan hits the sway bar) and then driveshaft, fuel, and power to the ecu and she should be ready to drive. Again moving slowly but surely
  7. #7
    O.G. Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft has a reputation beyond repute Fast Raft's Avatar
    Join Date
    Aug 2003
    Location
    The Burg
    Posts
    595
    Feedback Score
    This is a really kick ass project...subscribed.
  8. #8
    Join Date
    Mar 2005
    Location
    TnC
    Posts
    214
    Feedback Score
    well sorry to severely disappoint but this project has been put on the back burner. I have a Baby on the way now. Ill try and do little stuff in the mean time.
  9. #9
    Feel teh rally bishes! GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM has a reputation beyond repute GT4SOM's Avatar
    Join Date
    Aug 2003
    Location
    Riverview
    Posts
    1,728
    Feedback Score
    3 (100%)
    That will be the sleeper from hell! Good job
    1992 GTS 3sgte from hell! // 1990 GT liftback Stock 3sgte
  10. #10
    Registered User adriel1jzgte is an unknown quantity at this point
    Join Date
    Jan 2012
    Posts
    Feedback Score
    hey bro im traying to do the same project can u help me out with some information and what type of brakets to use for the motor mount do i have to costume make them or u know a place that sell them already make.thanks
  11. #11
    Join Date
    Jan 2012
    Posts
    Feedback Score
    can u help me with some info im doing the same project
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
