+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    grease monkey! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82's Avatar
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    7mgte engines, blocks, heads, and parts
    William Branan
    Spring Hill, Fl.
    williamb82@yahoo.com
    813-900-0677 text only please.
    if you are seriously interested in any or all of the stuff im about to describe, pm me. i havent gone through it all yet and dont plan to for awhile, but a serious interest with money in my face will get me off my butt. all the stuff is in spring hill, fl. I might be able to drive a lil ways to deliver some of it or meet somewhere, but do not have the ability to ship the big stuff. my back is screwed up so cant be picking this stuff up to pack it and then haul it somewhere to ship etc... i have listed the major stuff i can recall below.
    ive got an empty block which has already been checked out, magnafluxed, decked and tanked. it was not honed as i hadnt decided if i wanted to hone it for stock pistons or bore it for the forged pistons i used to have. it is the newer style block with the extra ribs on the side and wider main saddles, the machine work was done by engine lab a few years back. machine work cost me almost $400 alone. if no interest i may just use this block for my 6m build instead of the planned ge block. id like to get $300 for this. pretty firm. will not ship
    i also have a stock bottom end that is together, though the #1 piston is melted. it was not knocking but id rebuild it completely before using it anyway. i have a stock piston to replace the melted one. also have a set of std main and rod bearings with thrust washer and stock rings, all brand new in the boxes. $250 for this with the rings and bearings. $200 without them, and $75 for the rings and bearings separate i can ship the rings and bearings but not the bottom end.
    ive got some other misc 7mgte stuff. at least 3 stock mid sump oil pans. one has a punched hole i need to weld closed. junkyard did it to drain the oil. at least 1 stock oil pump, though id take it apart and clean it before using just to be safe. been sitting for years. ill include an oil pan and pump with the complete bottom end.
    if someone wants the whole engine setup out of my 84, ill take $2k. thats the complete engine as is, and it runs, but has water in the oil.it is bone stock except the arp head studs and mhg. it has water in the oil. idk if i blew the hg, or lifted the head the last time i drove it. it was ~30deg outside last time i drove it and i didnt look at the boost gauge. IJ from supraforums seems to think i just lifted the head and it prolly just needs a couple oil changes to flush it, but id recommend rebuilding. usually once water gets in the oil itll start knocking soon. and i say replace the hg as it may be blown. ill sell this as is with the exhaust manifold that has an egt bung in the #6 runner, and a 57 trim ct26 with ~35k miles on it. works perfect. i was running 18psi on it. egt probe not included, no flywheel/clutch. i should have a mid sump pan and pump for it if needed.egr port on the back of the intake and head are both blocked with a 3/8ths npt pipe plug. and i should have stock 86.5-88 mk3 motor mounts and brackets. 57 trim ct26, ms2 standalone with aem wideband, 4bar map sensor, pte 780cc/min low impedance injectors, 2nd fuse box which was setup specifically for the ms2 setup. it has 3vz individual coils, 2 ford edis ignition modules running on a 36-1 crank trigger firing the 6 coils in waste spark. gm air temp and coolant temp sensors, stock 7m tps. ill even give you the inlet pipe and cone filter, stock mk3 i/c and the pipes with tial knockoff 50mm bov. also the oil filter relocation kit. basically, its about as plug and play as it gets. all you have to do is hok some wires to power and ground and itll run. then of coarse your sensor wires. im keeping the water temp and oil pressure snesors as they are for my auto meter gauges.
    there will be no flywheel/clutch or trans. just the engine with the injectors, standalone, upgraded turbo, wideband. do not lowball me on this particular setup. it is currently tuned for 18psi in 80+deg weather. i will even provide the cd with the tuning software so you can install it on your laptop. or i can install it on the laptop for you to insure it is configured correctly.i will also include the tuning cable and disc for it. it is a serial to usb cable. im fairly firm on this price. i have prolly tripple this price into it. ill include some of my more recent msq files as well. $2000.00 for this. pretty firm on that as this is a steal on the whole setup.
    ive got other misc stuff. i think a couple of the water pipes that go around the engine. some lower timing cover setups to go with the blocks, some valve covers, couple crank pullies, motor mount brackets, i think i have a near new set of 86.5-88 motor mounts, maybe 2 sets, have to look. 1 set only has 500 miles on it iirc.
    didnt have time to dig everything out of the way to get pics of it.
    coil pack with no harness or wires. $40 shipped.
    lower intake manifold modified for 6 additional injectors, iirc it is setup for the larger 14mm injectors. never used since modded $200 obo shipped
    ive got a mk3 hks smf intake in the box. no filter element. but the filter housing is there and like brand new. no aluminum afm adapter but does have the hks coupler and clamps as well. carb sticker is gone. $40 shipped
    as you can see, ive got lots of stuff to clear out. if you are SERIOUS!!!!!, then pm me and lmk what your interested in and we can try to work something out.
    im also open to trades for 2j parts i need.
    2jzge fan clutch and fan blade (fan blade must be from a ge)
    2jzgte divided inlet turbo manifold, preferably new
    2jzgte billet tensioner bracket
    2jzgte top feed fuel rail
    2jzgte throttle cable
    2jzgte new oem oil pump
    2jzgte ati damper
    2jzgte new gates/greddy timing belt
    2jzgte adj timing gears
    2jzgte usdm cams, or better yet some 264's
    2jzgte new arp head studs
    2jzgte new flywheel bolts
    2jzgte/1jzgte tilton flywheel for 7.25in clutch
    also willing to trade some stuff for three 44/45mm side draft carbs. weber, delorto, solex, mikuni, etc... all 3 must match and be rebuildable. if youve got at least 2, lmk what they are, might still trade some stuff.
    http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
    http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
    http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
    http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
  2. #2
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    bump. need to sell this stuff
  3. #3
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    bump, sold the coil pack with msd wires, an empty 7mgte block and bare 7mgte head. still alot left to get rid of.
  4. #4
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
  5. #5
    ┌∩┐(◕_◕)┌∩┐ Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T has a reputation beyond repute Jordan T's Avatar
    Join Date
    Jan 2005
    Location
    727
    Posts
    16,970
    Blog Entries
    Feedback Score
    17 (90%)
    got a rear diff?
    Quote Originally Posted by La Flama Blanca View Post
    I like potatoes!
  6. #6
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    i got 2 diffs for the mk2. both are 4.30 with boken lsd's.
  7. #7
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    edited first post to remove stuff i have sold.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
