#1 (permalink) |
Car: kouki powered 180, jza70 single
sarasota
: 14201950 |
jz parts, ma70/jza70 parts
polished intake and valvecovers with polished ThrottleBody(400)
MK4 550cc purple(US market)OEM side feed injectors and OEM resistor pack WITH injector clips (200) RC 850cc top feed injectors (425) MTR 1jz top feed fuel rail black (250) JZA70 ecu perfect condition 5speed (150) SAFC2 mint condition all harness left (250) 1jz rods and pistons, oem used good condition (150) MA71 4.3 sport LSD-clutch type (center section)(350) 1JZused but perfect condition oem metal tri-layre exhaust manifold gaskets(25) possable sale: OguraRacingClutch JZA70 HyperSingle 409series clutch with push/pull converter/hubBearing (500)(needs rebuild) JZA70/MA70 turbo 5speed driveshaft (150) JZA70 TwinTurboR Torsen 4.10 diff center section with axle stubs(450) 1jz oem fuel rail (30) 1jz injectors oem yellows (100) many random toyota injectors 1jz idle motor (125) MK4 1jz/2jz water pump non hydro fan front AND rear, new condition(285) shortend 1jz throttle body (50) MA70 sawblades 16inch wheels black with great tread on nice tires (100) 1jz/2jz front sump oil pan upper and lower with pickup(250) 1jz/2jz rear sump oil pan upper and lower with pickup(250) used but in good condition 1jz/2jz turbo oil pump(55) JDM jza70 front fender trim blinker light deals(55) one plastic is cracked on bottom |
#7 (permalink) |
7M Under Construction
Car: 1988 Supra Turbo
Miramar, FL
: 10 |
I could use that driveshaft. let me know if you still have it
| Sponsored Links |
